Register Sweepstakes VB Image Host Members List LAN Calendar Search Today's Posts Mark Forums Read
LinkBack Thread Tools Search this Thread Display Modes
Old May 14, 2008, 05:13 AM
Default CPU Temperature E8400 3.0ghz
My CPU temperature is averaging around 55c - 61c at 60% load. Is that normal? or do I need to reinstall the heatsink.
When its not doing anything its around 42 - 48c for both cores.
http://img262.imageshack.us/img262/5267/cputempru2.png
Please tell me what I have to do :/
Old May 14, 2008, 05:26 AM
Babrbarossa's Avatar
Super Moderator
That probably too warm- what kind of cooler are you using? If you're not confident with remounting the CPU cooler there are lots of guides just a google away.
System1: evga 680i rev. A1 // Q6600 @ 3.51 // evga 8800 GTS 640MB // 2X2GB GSkill DDR2 1000// Antec TP Quattro 850w // CM Stacker 830
Water Cooling: D-Tech Custom Fuzion // Danger Den 680i chipset block // Swiftech Stealth// HW Labs Black Ice GTX Xtreme 360 // Swiftech mcp655 pump
System2: Asus Commando // e6400 @ 3.4 // Crucial Ballistix PC2 8000 // evga 7900GS // OCZ GXStream 700w // ACFP7 CPU cooler // Antec p180
Old May 14, 2008, 05:27 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
The CoreTemp readings are incorrect. The isssue is that CoreTemp takes its readings based on a TJunction of 100°C while the actual TJ of the Wolfdale chips is 90°C...or 85°C, I can't remember which off the top of my head. So, the ACTUAL temperatures are between 10-15°C than what you are seeing there.
Old May 14, 2008, 05:30 AM
gimark's Avatar
Level up: 43% Level up: 43% Level up: 43%
Level: 8 - 103 points to level up
That looks at least 15 degrees warmer than it should be. Can you show a core temp with your comp idling (15% or less load)?
edit: er.. what SkyMTL said lol.
Main Computer Specs: | Gigabyte DS3R rev 2.0 | Intel Q9450, Thermalright Ultra-120, Noctua fan | EVGA9800GX2 | Vista 64bit | G.SKILL F2-8000CL5D-4GBPQ PC2-8000 4GB| 2gb Corsair XMS2 | Antec 900 | Logitech z5500 | Samsung 226BW | Razer Barracuda and HP-1 | D-Link DNS-323 2-Bay Network Storage Enclosure w/ Hitachi 500gb | WD RaptorX 150gb x2, Raid 0 |Logitech mx5000 | OCZ 700w GameXstream
Old May 14, 2008, 05:44 AM
Here is a picture when its idle.
http://img206.imageshack.us/img206/5...apimagell2.png
Also can you suggest another program I can use? I only used Core Temp because this was the one I used before.
Also thanks for replying!
EDIT:
I used the Intel FAN that came with my CPU.
Old May 14, 2008, 05:54 AM
sswilson's Avatar
Super Moderator
Realtemp is gaining popularity as a temperature monitoring program.
Even with a stock heatsink those temps at idle seem a bit high.
Gigabyte P35-DQ6 / E8400 / 4X 1 Gig Crucial Balistix PC2 8500 / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S /
MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / Swiftech Apogee GT WB / Samsung 931BF
DFI P965-S Dark / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 /
Creative Audigy2 / NEXUS NHP-2200 / Swiftech H20-220 / Highspeed PC Tech Station / BENQ FP91G+
Old May 14, 2008, 06:12 AM
SKYMTL's Avatar
Realtemp is an option. Another option is to compare what your BIOS says you are idling at (which will be the actual reported temp without software getting in the way) and then compare that to what CoreTemp says. I bet you anything there will be a 10°C to 15°C difference.
Old May 14, 2008, 08:45 AM
When I restarted my BIOS was averaging around 36c
Is that normal?
Old May 14, 2008, 08:55 AM
Eldonko's Avatar
Hardware Canucks Reviewer
I would try reinstalling the HS, but it is not THAT much over normal either way. Remember the stock HSF is terrible.
Revolutionary Mule!
Old May 14, 2008, 08:58 AM
SKYMTL's Avatar
Whelp, there is the 10-15°C I was talking about. And yes, on the stock heatsink that is quite normal if VERY slightly on the mildly high side probably due to the ambient temperature of the room / case.
Forum Jump
Search this Thread:
Advanced Search
