| My Xeon E3110 (similar to E8400) bios shows the CPU idle at about 38-44 C on the P5K depending on the room temperature without any rear exhaust fans. After installing rear exhaust fan the temperature CPU temperature drop about 3 C. I will probably upgrade the CPU heatsink because the fan noise is still driving me nuts! Paphman910 |
| I'm just curious, not that this will have a whole lot to do with it but, would you be able to take a picture of the stock heatsink on the E8400 and post it. I just got an E7200 (also 45nm but the 3mb cache one) and it has the same "cut down" heatsink that you would get on a Pentium Dual Core ect. I still have one left over from my E6750 that I never used because I just went with aftermarket right away, and that one looks to be hands down the better cooler compared to the one that came with the E7200 (its the big one that has the copper bottom). I am just wondering weather the switched the rest of the 45nm CPUs over the the small heatsink aswell. |
| Quote:
I had my 8400 upto 3.8ghz before the stock cooler met its thermal limits.
__________________ CSE: Open Air MOB: Abit IP35-PRO CPU: Intel C2D E8400 @ 4.2ghz RAM: 4gb g.skill pc2-8000 GPU: XFX 8800 GT Alpha Dog Edition PSU: PC Power & Cooling 750w |
| Thread Tools | Search this Thread |
| Display Modes | |
