Old May 8, 2008, 08:06 AM
Rapid-X's Avatar
Default E8400 on ?
:rtfm:
i jsut got the E8400 no board all thanks to a error by a guy i bought a p5n32 Sli off, told me it was the E version turns out it doesnt support the cpu. Gonna sell the P5n32 sli to get some funds to try and get a nice Sli board for my E8400.
heres my problem wat to get. i want the cheapest board possible to run that processor and gimme some items to overclock to around 4ghz. and handle 2 8800gts 640 mb. with my ocz power supply i think it should be ok. but waht board would be the cheapst with sli and not all the bells and wisstles
Old May 8, 2008, 08:30 AM
Synth's Avatar
nVidia 750i motherboards :
- eVGA 750i
- Asus 750i
Cheapest SLI solutions that support Penryn cores.
Old May 8, 2008, 09:40 AM
The EVGA 750i is really nice, I have it. However I will warn you that there is a currently fairly serious bug with it.
Basically the SATA ports get locked if you try and use RAID on the mobo. So if you have two HDD;s on SATA and a DVD SATA; if you try and set up raid it thinks that you are using all four SATA ports; so then it won't boot because the mobo is trying to raid together the HDD's with the DVD drive. The only workaround right now is to use an IDE CD/DVD device if you plan to run RAID on the 750i. EVGA said they will fix it ASAP of course; so we shall see. Other than that the board is amazing, I love mine to death and it's been easy to work with so far.
Old May 8, 2008, 10:22 AM
Rapid-X's Avatar
welkl i have 2 sat drives and ide cd and dvd drives willin to run one in the mean time its jsut the cost that is killing me and i cant get Shi*t for this p5n32sli anymore just cause it doesnt support the new cpu's wish i could send it off someweare and get some value for it
Old May 8, 2008, 04:36 PM
JD JD is offline
I think it would be best to sell one of your GTS and get a Gigabyte GA-P35-DS3L since it seems like you don't have a ton of money left.
Old May 9, 2008, 05:55 AM
Rapid-X's Avatar
i might end up doin that thanks for the suggestion u interested?? lol
Old May 9, 2008, 01:31 PM
Rapid-X's Avatar
Asus P5KC good or bad?? gettin it for $100 after taxes
Old May 9, 2008, 03:31 PM
paphman910's Avatar
It is a good price. I would go for GA-P35-DS3L instead of the Asus P5kc if you are on a budget and plan not to use DDR3 RAM.
Paphman910
