Old November 21, 2014, 06:02 PM
eltiti55555's Avatar
Default What's a good heat sink for my CPU?
My current i5 2500k(@4.5Ghz) has a Coolermaster Hyper 212 Plus on it, which I would like to replace with a smaller heat sink because I bought 8GB of ram for my PC recently and I was only able to add 4GB (for a total of 12GB), because the heat sink was too big and wouldn't give me room to add the reminding 4GB.
Should I just use the stock i5 2500k even with the overclock I have on it?
Ideally I wouldn't mind buying a small and inexpensive heat sink that's better than the stock one.
What do you guys think?
Thanks!
Motherboard: Z97 GAMING 5
Processor: Intel Core i7 4770k (stock)
Memory: G.SKILL F3-1866C9-8GXM (x2) || G.SKILL F3-14900CL10-8GBXL (x2) (32GB)
Video Card : GIGABYTE GeForce GTX 1070 G1 Gaming
Hard Drives: Western Digital Caviar Black 1TB SATA3 6GB/S 7200RPM 64MB Cache 3.5IN Dual Proc Hard Drive OEM
SSD: Samsung 840 Pro
Power Supply: XFX XTR Series 750W PSU
Operating System: Microsoft Windows 7 Home Premium Edition 64Bit
Old November 21, 2014, 06:35 PM
sswilson's Avatar
Do you have a pic? Any chance you can rotate the heatsink 90 deg?
Old November 21, 2014, 06:38 PM
I thought that the sink was supposed to be in a fixed position?
Old November 21, 2014, 06:40 PM
sswilson's Avatar
It would offer better cooling with a fore - aft orientation so that airflow goes with the case but it can be rotated north - south if it conflicts with something on the board.
Old November 21, 2014, 06:52 PM
sswilson's Avatar
Also, are you running a push/pull? If so you can always try it with just one fan opposite to the memory side, or the fan that's blocking your memory can also be slid up the body a bit to provide clearance for the memory.
Old November 21, 2014, 07:04 PM
Desktop.zip - Speedy Share - upload your files here Here are some pics
I don't see how I could move it.
Old November 21, 2014, 07:20 PM
sswilson's Avatar
Heh... holy cwap dude... 8 minutes to download an image???? If you go into the advanced posting mode you'll see a paperclip up around the text formatting buttons... that'll let you upload and host the image right here on the website. :)
Old November 21, 2014, 07:29 PM
Yea, I tried that but it failed a few times.
Old November 21, 2014, 08:19 PM
sswilson's Avatar
Did you unzip the image?
Old November 21, 2014, 11:12 PM
There are 4 images, I took them with my cell and saved him in the PC and then I zipped them and uploaded them to that site. If you want I can just upload each image to a image hosting site instead.
Help Heat Sink SEVEN Troubleshooting 6 July 25, 2009 07:28 AM
Heat sink comparison Bones Air Cooling 11 March 27, 2009 05:07 PM
CPU Heat sink WolfBane Air Cooling 4 March 8, 2009 09:58 PM
what is a decent air heat sink Shadowmeph Air Cooling 13 January 8, 2008 06:46 PM
Modifying my CPU Heat Sink??? mattydies Water Cooling 8 June 25, 2007 09:03 PM
