Old October 21, 2014, 07:01 AM
Default PWM fan headers on Z97 mobos
So, after buying everything but the important stuff, I'm on the hunt for a z97 mobo. I'd like to control all my fans via PWM if possible.
I did some digging and found that apparently there's some controversy regarding "fake" 4 pin headers not actually being PWM. So far, only Asus Z97 boards have been found to be all PWM controlled.
Does anyone know of any other boards with lots of PWM headers?
Thanks!
Old October 21, 2014, 12:04 PM
Helios79's Avatar
This is the first I have heard about 4-pin headers not being PWM controlled. Frankly, it doesn't make any sense to soldier on a 4-pin connector and use only 3 traces to power the connector (unless you're MSI, and I won't go there...). If you read a 'supposed' thread on LTT about someone's rant, that poster is completely misguided on how PWM works. AFAIK, there is no controversy and that person is full of FUD. All my 4-pin connectors on my ASRock Z97 Extreme4 are PWM controlled.
Define R5 | SuperNova 750 G2 | GA-Z97X-Gaming 5 | i5 4690K @ 4.6 GHz | Nepton 240M | 16GB HyperX PC3-12800 | GTX 780 SC ACX | ALC 1150 with XB3 Software | HyperX Fury 240GB | Seagate 1TB | Windows 10 Pro x64
Antec 300 | ToughPower 700W | GA-Z77X-UD3H | i5 3450 | Hyper T4 | 8GB PC3-10600 | X25-V 40GB | Seagate 3TB 7200.14 | WDC Blue 3TB | Seagate 2TB 7200.14 | Server 2012 R2 Standard
HP Elitebook 8470p | i5-3210M | 8GB PC3-10600 | HD4000 | PNY CS1211 240GB | Windows 10 Pro x64
Old October 21, 2014, 07:55 PM
I'm afraid it's not FUD.
All of the manufacturers do it. It's not just MSI.
Give this thread a good read:
SPCR ? View topic - ASUS Z87-Deluxe fake 4-pin headers & other fan control info
Each generation motherboard makers are different. Some offer better controls one generation, then actually regress the next generation. It's really weird.
Old October 21, 2014, 09:05 PM
Helios79's Avatar
Well, it's nice to know that someone did take the time to properly explain on why ASUS chose to do what they did, instead of someone else posting a rant without providing any real technical evidence. I guess I'll have to start looking at the traces on new motherboards.
Rampage IV Extreme Fan Headers BobbyLou CPU's and Motherboards 11 December 30, 2011 10:17 AM
How to use usb headers? Blu Peripherals 2 January 11, 2011 08:38 PM
Motherboard Fan Headers Arcnor Air Cooling 5 June 9, 2010 02:23 AM
AM2 motherboard with 2 IDE headers? Perineum New Builds 8 April 8, 2009 10:34 PM
