Old October 7, 2014, 09:54 AM
Deeival's Avatar
Default Looking for LGA1150 mobo with descent onboard sound
Im planing to upgrade soon and was looking at a i7-4790K and a Gigabyte GA-Z97X-UD3H ($140).
Anything in that price range that I should look at instead? I'd like to have descent onboard sound.
Old October 7, 2014, 10:12 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Around that price range.
The ASUS Z97-A uses the older ALC892 but gives it a ton of upgraded circuitry to work with
Gigabyte on the other hand uses the newer ALC1150 and also features upgraded components.
Some folks think the 892 has a better sound profile than the 1150 but others think the exact opposite.
In the end, I really don't think you'll actually hear the difference between the two unless you're pushing out audio signals to a seriously high-end speaker system.
Onboard Sound better than Sound Card!? Evil Genius Jr. Audio 5 January 18, 2013 11:52 AM
What's with onboard sound these days? biff Audio 15 August 16, 2010 10:34 AM
bad headset or bad onboard sound? Remoth Audio 8 May 24, 2010 09:38 PM
Sound card VS onboard ToXic Audio 2 August 28, 2009 10:14 PM
No sound off my Onboard or my soundcard Shadowmeph Troubleshooting 3 February 27, 2009 05:37 PM
