Old August 11, 2014, 03:07 PM
Default Gigabyte H81m ds2 w/ I3 4150
Posted about it in my thread but figured I'd start one in the tech forum.
I cannot get this dang combo to post. I had someone updated the bios to latest using an older i7 processor, but it won't take. The system powers up for about 5-10 seconds then restarts. No display. The processor is listed as compatible on gigabytes site. I opened a ticket with them but I'm at a loss where to go from here.
It appears to be a compatibility issue but it shouldn't be. I found instances of other people using this processor with the h81 chipset.
Old August 11, 2014, 03:21 PM
sswilson's Avatar
Have you had the processor running on a different board? Seems to me this is the second MB, and you've proven that the board will post with a different processor.
Old August 11, 2014, 03:40 PM
Yes second mobo, the first one was legitimately dead, wouldn't even power on.
I haven't tried the cpu on a different computer although I did have ncix exchange it for a new one to make sure it wasn't a bad cpu. I will see if I can swap it into someones 1150 system for a test.
Old August 12, 2014, 02:57 PM
The cpu works fine with a different board... Gigabyte support so far has been useless lol. I told them what I updated my bios to and that I used an older haswell processor. They replied asking if I had an older haswell processor I could update the bios with. *facepalm*
Plan right now is to return the CPU and motherboard, then just go and get a new i5 and h97 board, then I won't have to worry about compatibility and I won't have to upgrade for awhile!
Old August 12, 2014, 07:32 PM
Your_friendly_gamer's Avatar
Good idea. I will have another 4670k combo up in a couple of days. 4670k z97-a mobo and gskill. 2400mhz 8 gig ram.
gigabyte 770 OC tragd Price Check 1 April 6, 2014 06:29 AM
Gigabyte X79-UD3 Justin Cider Price Check 1 April 5, 2014 05:56 PM
Gigabyte GA-H87N-WIFI vs Gigabyte GA-Z87N-WIFI? SAS CPU's and Motherboards 2 September 20, 2013 03:33 PM
Gigabyte GeForce GTX 670 OC sli vs Gigabyte AMD Radeon HD 7970 OC 3GB yehia7000 Video Cards 2 August 25, 2012 08:09 AM
[FS] Two Gigabyte GTX 460 1GB $150 Each $280 for Both riflepwnage Buy/Sell & Trade 1 April 30, 2011 10:40 AM
