Old June 19, 2014, 10:54 PM
Default Decent MPCI-E Wifi?
I'm looking to pick up a Wifi MPCI-E card for my Asus Gene V board. I won't be using wifi often, but when I do I want something decent for browsing and the odd online game. I don't want to spend a fortune either.
Is this something that would fit the bill?
Intel Centrino Advanced-N + WiMAX 6250 WiFi mPCI-E Adapter | laptop accessories | City of Toronto | Kijiji
Old June 19, 2014, 11:16 PM
MacJunky's Avatar
I do not see why not, unless you wanted a card with bluetooth. Intel has those as well.
Old June 20, 2014, 07:54 AM
MARSTG's Avatar
why do you want it on mini pcie alone? There is a lot of EMI interference on the mobo. USB would be a lot better.
Old June 20, 2014, 01:41 PM
I preferred something that wasn't sticking out of my case and figured if laptops used them, why wouldn't they be good. Is there no interference on laptops?
Old June 20, 2014, 02:38 PM
sswilson's Avatar
I just went through this with my mITX build. Don't forget that you'll also need to order antennas and find a place to mount them.
Old June 21, 2014, 10:44 AM
sf101's Avatar
I was just going to say laptops also have wire antenna that goes up the screen bezel
My 5 Current Rigs-Guest-Main-Work/Spare-HTPC-Laptop
I7-6700T-Work
3770K@ 4.8GHz -Main
2500k @ 4.7GHz -Guest PC
3570K @ 4.5 -HTPC
MSI GT70-2OC/770m-998/4800MHz -Laptop
SF101 HW BOT
Crossfired XFX290X@1150/1500mhz-EKWB (Main)|GIGA-OC7970WF3@1250/1850 (HTPC)
MSI 970GTX (Guest) ||Asus480GTX@900/2000 (work)
Old June 22, 2014, 02:54 AM
I recommend something newer.
the 6xxx series are old. get the newer intel 7260 series. They come in a variety of speeds and bluetooth options from N to ac, single and dualband
The best deal to get is the Gigabyte GC-WB867D-I GIGABYTE - Motherboard - GC-WB867D-I (rev. 1.0)
It has the latest 7260 AC and bluetooth and is complete with antennas. I have the previous version and the kit works well.
You canget it at Hookbag.ca GC-WB867D-I from Gigabyte - Gigabyte - Network - - Home Computer Parts, Computer Components, low price computer at Hookbag $33
There is a cheaper no frills N+bt mpcie card for less here 7260.HMWBNWB from Intel - Intel - Network - - Home Computer Parts, Computer Components, low price computer at Hookbag $13
search coupon site bargainmoose.ca for the free shipping code for new accounts.
Old June 22, 2014, 07:38 PM
There's no reason why I couldn't remove the PCI plate and use the card on my Asus Gene V right?
Old June 22, 2014, 08:10 PM
Yeah.
As you can see in the product image, you can remove the mpcie card from the pcie adapter. just like in a laptop, mpcie it is held down by 2 m2 screws.
Gigabyte GA-H87N-WIFI vs Gigabyte GA-Z87N-WIFI? SAS CPU's and Motherboards 2 September 20, 2013 03:33 PM
using router wifi if PC doesn't have wifi card? Shadowmeph Networking 12 May 4, 2013 05:47 PM
[WTB] Router or Decent Wifi Card/Dongle igot6strings Buy/Sell & Trade 33 February 6, 2013 07:01 AM
RDC over local Wifi vs remote wifi vs 3G Generic User #2 O/S's, Drivers & General Software 3 January 23, 2012 08:14 AM
Any decent KVM's for DVI and USB ? yamawho Display Units 0 November 5, 2009 03:43 PM
