Old May 24, 2014, 12:35 AM
ShinraCorp's Avatar
Default Hashwell refresh work on 8 series chipset?
Hey folks,
I was wondering if the refresh works with the 8 series chipset since I'm building a PC for my brother with spare parts.
Old May 24, 2014, 12:52 AM
Shadowarez's Avatar
Can't remember were I read but yeah it will work. With a bios update. If board supports a update.
Old May 24, 2014, 12:54 AM
Shadowarez's Avatar
Devil's Canyon on Z87 Platorm here ya go quick link from rog.
Old May 24, 2014, 01:53 AM
ShinraCorp's Avatar
Thanks, although that means I need a old hashwell to do an update don't I?
Old May 24, 2014, 03:22 AM
Shadowarez's Avatar
Id say give it time im sure there will be a bios update avaliable. Maybe depends on the mobo. Im sure the motherboard will least let ya in bios? Never had option to test it out though.
Old May 24, 2014, 03:37 AM
ShinraCorp's Avatar
According to Asus I need the old Gen hashwell to enter bios. Unless I do a USB flash of the bios
Old May 24, 2014, 10:59 AM
The “Devil’s Canyon” line of products for performance enthusiasts and overclockers feature marginally different packaging with improved thermal interface material, which promises to enable higher overclocking potential. While the chips come in LGA1150 form-factor, they are only compatible with the Intel Z97 and the Intel H97 platforms.
Intel ‘Devil’s Canyon’
Devil’s Canyon is the new code-name for a new unlocked (K-series) CPU exclusively for Intel 9-series motherboards.
exception seems to be the 20th anniversary Pentium which Z87 will support.
Old May 24, 2014, 11:03 AM
Bond007's Avatar
^^^+1 The last I read all haswell refresh are fine on z87 with a bios update (4790/4690), but the yet to be released devil's canyon will need z97.
Old May 24, 2014, 11:11 AM
Pre-order prices of G3258, i5-4690K and i7-4790K unlocked CPUs
Here are the specs and prices for Intel's Haswell Refresh CPUs - The Tech Report
haswell refresh can be seen as devils canyon (3 chips) or the whole slew of 20 something chips, everything I read says DC is only properly supported by the 9 series chipsets (also meant for broadwell)
Asus says one thing, and yet Intel documentation says another.
Old May 25, 2014, 08:11 PM
Trial Member
Just got a link-back on ROG site and need to clarify any misunderstanding.
Devil's Canyon = upcoming K series CPU, not the Pentium Anniversary Edition. They are two different things.
The ROG article does not expressly state Z87 supports Devil's Canyon, and Intel has yet to confirm the details of this CPU and ASUS cannot comment until Intel does.
Regarding USB BIOS Flashback: you do not need a CPU at all. You just need ATX power and FAT32 formatted USB drive plugged into the appropriate port (see the manual), then press the button on the rear IO.
All ROG Z97 motherboards feature USB BIOS Flashback.
Is my PSU Hashwell compatible? ShinraCorp Power Supplies 11 April 22, 2014 10:40 PM
ASUS Shipping Updated Intel 6 Series B3 Chipset-based Motherboards This Week FiXT Press Releases & Tech News 4 March 2, 2011 10:43 PM
Intel 6 Series Chipset Debacle: Manufacturer and Retailer Responses FiXT Press Releases & Tech News 29 February 1, 2011 05:48 AM
Upcoming ATI Radeon 5000 Series Refresh info [Wiki] mattlef Rumor Mill 29 February 19, 2010 10:55 AM
Making SLI work on ANY chipset MB MarkOne Video Cards 1 November 2, 2009 08:39 PM
