  #21 (permalink)
Old May 17, 2014, 09:41 AM
Originally Posted by Raja View Post
Can you list all USB devices plugged into the board and which ports they are in please?
Need to pass to HQ for replication.
Hey,
I think I got rid of the problem by capping the cpu vcore first to 1.25 and then i upped it to 1.275 @ 44 multiplier to get stable and haven't got it since (only a few hours of stress testing + a day of gaming, but the problem showed up usually within 20 seconds under load). I have a hunch the mobo just didn't like vcore going into 1.3+ under stress testing. Need to try and reproduce it myself when I have time.
I think I had the problem occur with nothing but a single keyboard/mouse plugged in any port. But mostly had a Ducky Shine 3 and a Mionix Naos 7000 in the rear ports (of course tried all of them to no avail).
  #22 (permalink)
Old May 17, 2014, 11:06 AM
MAC's Avatar
MAC MAC is offline
Associate Review Editor
Originally Posted by negis View Post
Hey,
Do you have any of the ASUS software installed? Also, what OS are you using?
  #23 (permalink)
Old May 17, 2014, 11:19 AM
Only installed the LAN driver from ASUS site since it wasn't working at all and flashed the BIOS to 0702. Running Win 8.1 x64.
Just noticed there's a 0902 BIOS available. Might give it a go in a few hours and also see if I can reproduce the USB power surge problem.
  #24 (permalink)
Old May 17, 2014, 11:23 AM
MAC's Avatar
MAC MAC is offline
Hmm, so you didn't install the Intel USB 3.0 driver? I ask because I've just now isolated that as the cause of the error on my end.
I was using Win 7, so I had to install the driver, but it may already come pre-installed with Win 8.1.
  #25 (permalink)
Old May 17, 2014, 12:10 PM
It turns out I did ;) Had the chipset installer package in my downloads after all - installed it just now to confirm -> instant power surges in prime95/IBT (with my stable 1.275V settings) - uninstalled it and no surges to be seen :)
Thanks for figuring it out!
  #26 (permalink)
Old May 17, 2014, 12:59 PM
MAC's Avatar
MAC MAC is offline
My pleasure!
  #27 (permalink)
Old May 21, 2014, 01:44 AM
Manufacturer Rep
The Intel USB 3.0 driver reserves memory space (for performance like IRST I think). Could well be there is some instability related to the overclock itself that does not result in the stress test failing but does result in the driver falling over. Fix would be to try and dial it out with the system voltages if possible. Does it happen at lower OCs where the CPU is in its "comfort zone" as well?
-Raja
  #28 (permalink)
Old August 5, 2014, 09:54 PM
Trial Member
May I ask what method you used to uninstall it? I know this is an old thread but I just upgraded to a Z97-A/4790k and I can't OC at all because of this damn "power surge on USB" error. I've tried uninstalling through device manager but it just reinstalls it on reboot. There's no specific program for that driver package like there used to be, did you just uninstall all the chipset drivers?
ASUS Sabertooth X79 Motherboard Review Comment Thread SKYMTL CPU's and Motherboards 18 August 11, 2016 09:02 AM
ASUS Z87 Deluxe Motherboard Review Comment Thread SKYMTL CPU's and Motherboards 22 July 11, 2013 07:59 PM
ASUS Sabertooth 990FX AM3+ Motherboard Review Comment Thread MAC CPU's and Motherboards 49 October 15, 2011 02:54 AM
ASUS P7H57D-V EVO LGA1156 Motherboard Review Comment Thread MAC CPU's and Motherboards 1 June 6, 2010 02:40 PM
