Dilemma DFI LP LT X48-T2R or Maximus Formula as title saysim having trouble deciding between DFI LT X48-T2R or the Maximus Formula they are priced similar although ones x48 chip the diff between x38 is little to none :blarg: anyone have suggestions or experiences with these boards? thanks in advance :thumb: |
DFI all the way |
DFI will be better if you're experienced. Assuming your overclocking of course. I have the Maximus Formula, and it can be flashed to the Rampage Formula (X48) quite easily. It's a solid board, I've had no issues with mine. |
