  #21 (permalink)
Old May 5, 2008, 09:52 AM
SugarJ's Avatar
Try CPU-Z or Everest, they usually tell you the make/model of the mobo.
  #22 (permalink)
Old May 5, 2008, 09:57 AM
Rapid-X's Avatar
lol its not running and i have no way of gettin it to run i dont have a low end cpu to update bios so im screwed.
  #23 (permalink)
Old May 5, 2008, 10:01 AM
SugarJ's Avatar
Oops. Forgot about that. It's usually stamped somewhere on the mobo. If it doesn't say SE it isn't. What CPU did you have in there before?
  #24 (permalink)
Old May 5, 2008, 10:23 AM
Rapid-X's Avatar
its new no cpu in before this one
  #25 (permalink)
Old May 5, 2008, 12:44 PM
JD JD is offline
Hate to break it to you but as far as I know the nForce4 does not support 45nm CPUs. It doesn't even support Core 2 Duo.
Looks like your going to need a new motherboard...
  #26 (permalink)
Old May 5, 2008, 01:36 PM
Rapid-X's Avatar
got any sitting around??jsut need to power my e8400 i will hold off on the sli setup for now
  #27 (permalink)
Old May 5, 2008, 01:52 PM
Rapid-X's Avatar
what cpu do u recommend that would fit this stupid board around the same performance and even chaper thatn what i paid for this cpu $227??
  #28 (permalink)
Old May 5, 2008, 01:57 PM
P5N32-E SLI is not nforce4 :P its 680i which supports C2D and the 45s just not the quad 45s
  #29 (permalink)
Old May 5, 2008, 02:09 PM
Rapid-X's Avatar
P5N32-E SLI?? how can i tell if mine is the E version. about to head home to trouble shoot let me kno in 2 hours lol if not im up for suggestions for a new cpu taht is gonna run nice in that mobo
  #30 (permalink)
Old May 5, 2008, 02:25 PM
Jack Rabbit's Avatar
The "E version" is a totally different board. if you have what you said you have in the OP you have this board which is an nForce4 board. Alternately, you may have one of these oh so confusingly named boards.
Asus P5N32-E SLI Plus - hybrid
NVIDIA® Dual X16 SLI
(C55+MCP55P; a.k.a. nForce®650i SLI & nForce®570 SLI)
ASUS HybridUp Technology
* Support SLI-Ready Memory Technology
Asus P5N-E SLI - 650i board
NVIDIA nForce® 650i SLITM
Asus P5N32-E SLI - 680i board - it is exactly the same board as the top-o-the-line Striker Extreme just without some of the fancy lights and such.
NVIDIA nForce® 680i SLI™
I think you would have to look at the box, if you still have it, or on the board itself for the exact model name.
- James Graham
