Old May 5, 2008, 12:54 AM
No.
You need a speaker.
Single beep = all good.
Any other beeps = bad.
No beeps = bad
Old May 5, 2008, 02:36 AM
Rapid-X's Avatar
plugged in speaker, the status light on the board is solid green but when i hit the front pannel power button to start it up nothing happens, could the board be dead even with a solid green button or is there something else i can try??
Old May 5, 2008, 02:37 AM
have nothing connected except cpu and see if you get beeps :P
Old May 5, 2008, 04:44 AM
Rapid-X's Avatar
so disconect hd ram and cd drives
Old May 5, 2008, 05:01 AM
Rapid-X's Avatar
o yeah also if the light is on the board is good rite??
Old May 5, 2008, 07:11 AM
Rapid-X's Avatar
crap sittin here at work i figured it out i need a older cpu first to install and update the bios before i can plug in the E8400. now were can i get a free cpu to test it with
Old May 5, 2008, 08:33 AM
sswilson's Avatar
Try putting up a request in the Buy and Sell thread for a loaner CPU in GTA. If you were here in HRM I'd be able to help you out, hopefully somebody local to you has a chip which can be swapped in for the flash.
Old May 5, 2008, 08:42 AM
Rapid-X's Avatar
anyone kno what bios version for the P5N32sli deluxe will accept the E8400??
  #19 (permalink)
Old May 5, 2008, 09:31 AM
SugarJ's Avatar
I don't mean to be the bearer of bad news, but Asus site doesn't show E8400 in their CPU support for that mobo. I'd try to update to the latest bios 0502 beta, but the chipset may not support 45nm CPU's.
http://dlsvr03.asus.com/pub/ASUS/mb/...Deluxe0502.zip
Apparently the P5N32-SLI Deluxe SE version supports Core 2 Duos? Do you have this or the original Deluxe?
  #20 (permalink)
Old May 5, 2008, 09:50 AM
Rapid-X's Avatar
how can i tell ??the one i have has onboard sound card ingrated.
