Old February 10, 2014, 10:14 AM
Shadowmeph's Avatar
on my asus sabertooth motherboard running a 1100 ti CPU on water used to run pretty warm also but I alsos noticed that the chipset or what ever it is called right above the CPU was pretty hot, I put a small fan on it and it actually brought down that temperature of that chipset as well as my CPUs temperature a few degrees. check the air flow of your case.
