Old January 28, 2014, 04:44 PM
Cheator's Avatar
Default i7 860 to AM3+?
I made this nice detailed thread and it got deleted, probably in the maintenance.. dammit.
Anyway, I'm looking for a few opinions. Its been a few years since I've kept up with CPU/Mobo news and you guys might be able to help out.
My main gaming rig is as follows:
Core i7 860
Gigabyte P55-UD3R
16 GB ram
2 x vertex 4 128GBs
Nvidia 560 Ti
While this rig is amazing, and still plays most of the latest games after 5 years, I'm looking to move to something with more modern conveniences (PCIE 3, USB 3 etc, EUFI, etc). Would I see much of a gain if I were to move to a 6 or 8 core AM3+ chip? Or is there a a cheap i5 on socket 1150 that I could move to that would be much better?
Primary purpose would be gaming, and any input would be appreciated.
Thanks!
My Heatware![/SIZE][/FONT] | Got RMA? Tell us your experience! | VOIP Help? PM ME!
Old January 28, 2014, 05:32 PM
Dzzope's Avatar
Bump the GPU and oc that chip and you'll be all good...
If you really want the usb3 etc(though not much fully uses usb2 never-mind 3 as far as most people accessories go) then your best bets are an i5 or the 8320 from AMD...
Nothing from AMD really touch even the old i5's / i7's for single thread performance. I'd drop in a 770 or similar and call it a day.
Or if it's still good enough... wait till the summer... there s allot of hype for the maxwell chips which should be rolling out in Q2.
Random quotes:
AKG: "So please don't piss on people and claim its raining. "
Soullessone21: "Their the only fat bitches I ever want in my wife :)"
DeeraxTheCoolNemo: "I never preSs CaPLoCK I just HiT my keyS so Hard ThEY Crit"
Bond007's Avatar
I would say going to AM3+ from the 860 would be pretty much a side step for gaming (probably offer the same fps), but would likely use more power. You would basically be changing over for the extra features on the motherboard (I wouldn't do it). Going to an haswell (1150) i5 would POTENTIALLY improve game performance and lower power consumption, while also getting you the usb3 etc.
In all honesty, unless you need one of the new features on a new motherboard, all you need to do for a nice gaming computer is make sure your power supply is still decent and drop in a new video card (gtx 760 would be a solid choice). Going to a gtx 760 or similar would probably give you close to double the fps of your gtx 560.
AnandTech | Bench - GPU13
Old January 28, 2014, 05:41 PM
Cheator's Avatar
Fair points from you and above, but would a 760 not be a bit throttled by PCIE 2.0? Also, I/O is probably restricted by my SATA, I would imagine that would give quite a bump as well. Thoughts?
Old January 28, 2014, 06:38 PM
Nope unless you run it at x4: Ivy Bridge PCI-Express Scaling with HD 7970 and GTX 680 Review | techPowerUp
AnandTech Portal | The Radeon HD 7970 Reprise: PCIe Bandwidth, Overclocking, & The State Of Anti-Aliasing
For very high resolution, the PCIE 2.0 x8 begins to suffer, but the 760 itself would be the bottleneck before the PCI-E at those settings.
I noticed my upgrade to SATA 3.0 with a Kingston HyperX SSD, but unlike jumping from HDD to SSD, it's more of a luxory than a productivity boost.
Old January 28, 2014, 07:41 PM
Bond007's Avatar
From what I have read pcie2.0 is not going to be an issue until quite a bit above the performance level of a gtx 760. I doubt it would be an issue on a gtx 770 either.
Old January 29, 2014, 06:31 AM
FreeKnight's Avatar
Frontier is dead on. There's not much of an issue with throttling for most on PCIe 2.0 at the moment. I'm in a similar situation to you (i7 920, OC'd to ~ 3.6 most of the time), but I scooped up a G1 Sniper when they were on sale so I got a 1366 board with SATA III and USB 3.0. I'd say it's worth looking for a used board that has those functions and keeping your 860, or picking up a Haswell setup. The only thing on your system where I can see the interface being a problem would be the Vertex 4s. They might be choked a bit on SATA II. Fortunately HWC has a solid review by AkG showing that it's not too terribly throttled OCZ Vertex 4 128GB SSD Review
Haswell-E is supposed to be out for Q3/Q4 this year IIRC. Allegedly with DDR4 support, so it may have a bigger performance bump for you. With new architecture, cpus and DDR4, expect to get fleeced at the cash register though :S
Old January 29, 2014, 09:00 AM
Cheator's Avatar
Thanks for all the input, good to know about. I've also been offered to trade my 860 rig for an LGA 2011 i7 and motherboard, so I'm going to take that. That should alleviate any bottlenecks anyway.
Thanks guys!
Old February 26, 2014, 10:11 AM
perfect cure.
Old February 27, 2014, 06:33 AM
Cheator's Avatar
Originally Posted by highpie View Post
perfect cure.
I actually didn't end up getting it as it didn't come with a cooler. So I'm back on the market, and still considering.
