Old January 13, 2014, 07:51 PM
wirerogue's Avatar
Default Maximus V Extreme 4 way crossfire
has anyone been able to get all 4 gpus to show up in the bios on a maximus v extreme?
when i fill all the slots with 4 r9 280x, the bios reports slot 3 as not present. i'm using all the red slots.
if i flip the dip switch and disable slot 4, then slot 3 is present.
i thought this board would work with 4 way setups.
anybody know the secret to get this to work?
thanks
Old January 13, 2014, 09:37 PM
ZZLEE's Avatar
Do you have the PCI 6 pin plugged into the board. ??
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old January 14, 2014, 10:14 AM
wirerogue's Avatar
yes, i have the EZ PLUG connected to the board.
i was going to do some mining with this rig and i can get 4 cards running in the red slots 1,2 & 4 plus 1 connected to the small 4x slot.
i was hoping to have 5 cards total connected eventually
the only thing i can figure is maybe my choice of cpu? i put a celeron g1610, which is an ivy bridge cpu but, i noticed the specs say it's PCIE 2.0. not sure if i need a PCIE 3.0 cpu to run cards in all the big slots. can't find any info anywhere on this.
Old January 14, 2014, 12:46 PM
Master_Shake_'s Avatar
do they all show up in the bios under
advanced/system agent configuration/nb pcie-configuration?
i have the same board and i hope you get this sorted.
found this
http://rog.asus.com/forum/showthread...s-Card-Problem
Old January 14, 2014, 12:53 PM
wirerogue's Avatar
that's where they are not showing up. i'll just run the 4 cards for now using the 4x slot instead of all 3 of the big slots.
thanks for your guys help. here's the build. http://www.hardwarecanucks.com/forum...ing-build.html
New Build: Sandy X79/Rampage IV Extreme VS Ivy Z77/Maximus V Extreme . . . Questtt3 CPU's and Motherboards 3 October 20, 2012 08:46 AM
maximus Iv extreme z68 BobbyLou Price Check 2 August 4, 2012 10:38 AM
maximus extreme and cpu jewellzy CPU's and Motherboards 5 May 29, 2010 05:07 PM
ASUS Launches the Rampage III Extreme and Maximus III Extreme Motherboards FiXT Press Releases & Tech News 4 April 16, 2010 05:40 AM
Maximus III extreme? BobbyLou CPU's and Motherboards 8 April 7, 2010 08:51 PM
