Old January 10, 2014, 01:33 AM
SAS SAS is offline
Default Mini ITX with WIFI..
I want a cheap Mini ITX with wifi - this build is a delayed build for my wife and she will do no OC and she will use the onboard graphics (i3-4130) but she will need WIFI.
What can you recomend? All I see is the Gigabyte GA-Z87N-WIFI.
Old January 10, 2014, 08:40 AM
FreeKnight's Avatar
If you're not set on Intel, there's a couple AMD boards with wifi that are m-itx. Such as this Gigabyte;
Newegg.ca - GIGABYTE GA-F2A88XN-WIFI FM2+ / FM2 AMD A88X (Bolton D4) HDMI SATA 6Gb/s USB 3.0 Mini ITX AMD Motherboard
Plus AMD integrated graphics perform much better than the intel ones at the moment.
I'm not sure if there are intel boards with integrated wifi off the top of my head, but it's easy enough to get a USB adapter that works well. I'd recommend looking at something like an ASUS N53 or something.
Old January 10, 2014, 06:01 PM
At this point I'd be looking for WiFi on the 5GHz band (search for ac or a/b/g/n) - at least where I live 2.4GHz is so bad I only use it for occasional browsing on tablets and phones.
The only one I can see that doesn't go into crazy prices is this one: GIGABYTE - Motherboard - Socket 1150 - GA-H87N-WIFI (rev. 2.0)
Look at the rev. number though, since the Rev 1.0 of the board is 2.4 GHz only.
Old January 11, 2014, 11:42 AM
Shadowmeph's Avatar
is it bad becasue of allot of people using the 2.4ghz range?
using router wifi if PC doesn't have wifi card? Shadowmeph Networking 12 May 4, 2013 05:47 PM
RDC over local Wifi vs remote wifi vs 3G Generic User #2 O/S's, Drivers & General Software 3 January 23, 2012 08:14 AM
ZOTAC announces the Z68-ITX WiFi series mini-ITX platforms at Computex Sam_Reynolds Press Releases & Tech News 2 May 31, 2011 12:42 PM
ZOTAC Revolutionizes ION With Intel CULV-Powered Mini-PC and Mini-ITX Platforms FiXT Press Releases & Tech News 5 August 27, 2010 01:48 PM
Lian Li Launches PC-Q08A/B/R Mini Tower Chassis for Mini-ITX and Mini-DTX FiXT Press Releases & Tech News 1 April 29, 2010 09:17 PM
