Old January 2, 2014, 06:49 AM
Shadowarez's Avatar
Question Motherboard Backplates
In building this Beast of mine I found yet another area I'd love to mod anyone know we're I can find Lga 2011 Backplates for cpu.
I want a stronger then oem provided one and plan to toss heatsinks and a fan on this sucker.
But few Google searchs turned up no real info on buying custom ones or manufactured ones. Anyone know of place that may carry such things.
Old January 2, 2014, 07:20 AM
sswilson's Avatar
Most after market coolers will come with a backplate of some form. If not you can always pick up the least expensive after market cooler that comes with one and just use the backplate.....
http://products.ncix.com/category/cp...-1023-1399.htm
Old January 2, 2014, 07:56 AM
BigPhatPaulie's Avatar
What's wrong with the huge backplate that Intel specs for every 2011 board? I doubt that anyone has bent or damaged a 2011 board due to large heat sinks so why the need to change it?
FOR PONY..... that is alll
Old January 2, 2014, 12:24 PM
Shadowarez's Avatar
seen mod were ppl attach active cooling. to the backplate lol thinking id need it for my Ivy-E 4960X.
Old January 2, 2014, 12:33 PM
Shadowarez's Avatar
this is the link lol thinking of more coolin for my build LGA 2011 CPU socket backplate cooling modification | Active Lga back plate Cooling
Old January 2, 2014, 12:49 PM
KaptCrunch's Avatar
why alu heat sinks when copper does it better, an the case air movement helps a lot or use heat pipe heat sink for the base screws are same pattern, just drill out mount stud and use nut/screws
Old January 7, 2014, 08:35 PM
Shadowarez's Avatar
Oh yeah I'll be using copper heatsinks just done same way as his mod.
Old January 7, 2014, 09:10 PM
JD JD is offline
AFAIK your not supposed to remove it. Even the Heatkiller backplate for my block went over top of the Intel backplate. Pretty sure it holds the socket retention piece in-place.
Old January 8, 2014, 02:35 AM
Dzzope's Avatar
For someone to go through that much trouble and to have push pull etc etc he's using AS5 compound which is worse than the best for temps by ~4-8c.. Just find it funny that all the attention to detail, work and money spent and they don't use the best (or even best bang for buck) thermal compound.
Random quotes:
AKG: "So please don't piss on people and claim its raining. "
Soullessone21: "Their the only fat bitches I ever want in my wife :)"
DeeraxTheCoolNemo: "I never preSs CaPLoCK I just HiT my keyS so Hard ThEY Crit"
Old January 8, 2014, 04:32 AM
Shadowarez's Avatar
Once I get to this point it will be to just prolong the system and means it's running. I'll be looking digging up best thermal grease I can find.
[FS] ALL SOLD!!!!: 2 x Evga GTX 580 Classified Ultra 3GB w Backplates rjbarker Buy/Sell & Trade 10 April 24, 2013 05:48 PM
[WTB] 2 BackPlates for MotherBoards trayton Buy/Sell & Trade 11 January 9, 2012 07:53 AM
GTX 580 Backplates ! rjbarker Video Cards 35 January 5, 2011 10:15 PM
Where to buy custom GPU backplates? Cowboy Off Topic 5 October 4, 2009 10:47 AM
Xigmatek Backplates JD Air Cooling 7 August 6, 2009 08:18 PM
