Old October 9, 2013, 01:20 PM
Birk's Avatar
Default Maximus Formula Waterblock
Hey, Thinking of getting a Maximus VI Formula board this week. Just wondering if anyones had much experience using the Mosfet block that comes preinstalled. I know the block itself is Aluminum which isn't that great.
I would consider the Extreme Board with an aftermarket block but I want the onboard sound of the Formula board. Do you think the aftermarket cooler for the Extreme would fit the formula board?
Old October 10, 2013, 02:24 PM
If you're going to spend money on a new block maybe you could consider a tiny pump from ek and a single rad and run the aluminum block in its own tiny loop. Like a dcp series.
Old October 11, 2013, 01:26 PM
hero1's Avatar
I checked the boards and blocks and they are not going to fit. You might as well just buy the board and replace the block with an XSPC block if you don't want to buy the EK block.
Old October 13, 2013, 09:22 AM
lowfat's Avatar
I would recommend not using the MOSFET block. Aluminium in a loop is a recipe for disaster, anodized or not.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old October 17, 2013, 03:15 PM
hero1's Avatar
Why is that? Can you please elaborate.
Old November 1, 2013, 06:46 PM
you shouldnt mix metals in your loop as it will lead to corrosion. if you do you will need add anti-corrosion fluids to the loop
Old November 1, 2013, 07:19 PM
Birk's Avatar
Ive decided to go with the formula now that EK is making a proper full board block very soon
Old November 1, 2013, 07:26 PM
If you mix metals you simply need to use glycol in the loop... but your cooling performance goes way down and you can't dump this stuff down the kitchen sink either.
option 2 is dual loops (I've tried it... it sucks)
Really gotta try and keep the metals the same if possible. Decent nickle blocks and copper work well enough but if you can stick to just copper all the way through you'll not have to deal with galvanic corrosion and electrolysis. Brass is also non corrosive.
Mah Rig now
Mah Rig before
My stuff for sale.
Maximus III formula BobbyLou CPU's and Motherboards 2 November 18, 2009 04:04 PM
[FS] Swiftech NBMax waterblock for Maximus II Formula ImmaPC Buy/Sell & Trade 21 September 12, 2009 11:09 PM
Striker II Formula or Maximus Formula II trayton CPU's and Motherboards 1 August 30, 2009 03:04 PM
WTB Maximus Formula SE MarcusFoX Buy/Sell & Trade 10 July 16, 2008 02:47 PM
maximus formula shortestraw RAM 7 April 29, 2008 08:56 AM
