Old October 9, 2013, 02:30 PM
3.0charlie's Avatar
That issue happened over a year ago, I don't remember the exact driver versions used.
John
Hydro-Quebec is salivating...
Old October 9, 2013, 03:32 PM
Shadowmeph's Avatar
Pull the audio card out and see if there is any difference I have an xonar DX card a couple of years ago also and it did the same thing I pulled the card and it solved the problem I am thinking it was driver problem I tried the card on a couple of different Systems it happened on all accept for my 2p folding machine but that was with newer drivers .
but if you pull the card and the same issues still happen then I suspect malware or the like
Old October 9, 2013, 03:51 PM
sounds like a software related problem to me... I've seen this happen with Asus networking control software. I've also seen this happen with Curse client for WOW.
Mah Rig now
Mah Rig before
My stuff for sale.
Old October 10, 2013, 12:11 AM
I am starting to suspect too if the new Asus drivers are causing this problem. So I will first target the audio card via drivers and physically pulling it out and checking. If this remains then I will cater to the malware suspicion.
I will keep you guys updated on how this goes. I will have access to my system sometime next weekend to run the tests.
Thanks.
Anvancy
Old October 17, 2013, 10:39 PM
So the update is this. I went according to what charlie said and I think he is right on track. I physically removed my xonar D2x, started the machine and tested it.The boot was relative fast,stability was good,music played instantly and the stutter was at a minimal.
So I removed the Xonar drivers,ran driver fusion and installed the UNI drivers of maxxedtech.Again I am facing the same exact problem.So is there a clash that is happening between my onboard Realtek Audio and Asus one?the onboard is set to ON in BIOS.
Anvancy
Far Cry 3 PC video stuttering. FrostbittinHD Gaming 23 January 2, 2013 09:54 AM
Micro Stuttering lelionmoddeur Video Cards 4 September 29, 2012 02:32 PM
Possible Stuttering Fix at a loss Ash Troubleshooting 9 December 21, 2010 01:51 PM
Computer stuttering DragonFlame Troubleshooting 22 August 14, 2009 08:12 AM
New rebuild, OS stuttering howettl Troubleshooting 26 July 17, 2008 08:58 PM
