Old September 19, 2013, 03:52 PM
Default AMD 8350 vs Intel 4770 vs XeonE3 for 3Ds Max/Solidworks/Autocad
Hi guys =)! I am some what new to pc building and i am sorry if i will ask dumb questions ^^ I am looking to build dedicated desktop for rendering and working primary in 3Dmax and Inventor(solid works). i watched many videos on different bench mark tests, and what i figured that there is no huge difference between them i understand that intel is a bit faster when it comes to gaming, but as i understood most games dont use more then 2 cores. So would it actually mean that FX8350 8 core at 4 Ghz will out perform XeonE3 1220 with 4 core and less speed. Certainly Xeon will cooler, more stable and lasting, i assume, for this type of task but will it be as fast, i will put good cooling regardless what processor i get so i am not worried about frying any off them. the hole thing with 4 core outperforming 8 core processor with ruffly the same speed is really confusing Please could some one explain it, it be so awesome!
Best Regards!
Old September 19, 2013, 04:54 PM
Well if you got the money, go with the i7. However, if you're cash strap, the FX8350 doesn't seem to be too slow in 3DMax 2011.
AMD FX-8350 Processor Review: Tuned-Up Bulldozer. Page 7 - X-bit labs
Old September 19, 2013, 05:17 PM
hey it clears thing up a bit! Thank you!
Old September 19, 2013, 06:54 PM
Bond007's Avatar
Basically intel gets the job done more efficiently. There are some tasks where the 8350 is just as fast as the i7, but the 8350 also uses more power while operating. In games intel does have a fps advantage as long as you have a graphics card that lets you take advantage of it. As mentioned above...my vote goes to the i7 unless you really can't stretch the extra $.
Old September 20, 2013, 07:36 AM
great_big_abyss's Avatar
[snip]. So would it actually mean that FX8350 8 core at 4 Ghz will out perform XeonE3 1220 with 4 core and less speed. [snip] the whole thing with 4 core outperforming 8 core processor with ruffly the same speed is really confusing Please could some one explain it, it be so awesome!
Best Regards!
Look at it this way:
Intel and AMD use different ways to get the same result. AMD does calculations one way, and Intel does them another. The information fed into the processor is the same, and the information spat out is the same, but the process is different.
For the same speed and cores, AMD's process happens to be slower than Intel's. AMD needs more cores and more GHz to do the same amount of work. At the same time, because they need more cores and Ghz to work, they use more power/produce more heat.
Therefore a higher clocked AMD processor will be equivalent (or worse) than a lower clocked Intel processor.
Follow the advice above. If you can afford it, go Intel. If you can't, the AMD will be a perfectly good chip for your application.
Autocad image conversion ? Mark Cases 2 September 20, 2013 06:27 PM
AutoCAD Architecture Build JD New Builds 6 April 15, 2012 08:32 AM
AutoCad cross platform support ZZLEE Mobile Computing 1 August 29, 2011 07:22 AM
Autocad 2010 Student ??????? MarkOne O/S's, Drivers & General Software 14 December 8, 2009 04:12 PM
For-Cad-solidworks-mobile-output2 a monitor mailaw Mobile Computing 1 December 21, 2008 08:39 AM
