Old September 6, 2013, 12:24 PM
Default i7 3770 prob with cores !!!!
hello
i am having difficult time with 3770 as Intel suggest that 3770 uses 1 and 2 core at 3.9 GHz and 4 core at 3700 MHz at full load .. but my 3770 is running at 4 cores even the system usage is 5 % why this is happening and the temps iam getting also is 55c to 60c !!! are temp going rise if the cpu uses 4 cores iam using asus h77 v and 650 psu '
Also i have check bios setting ....when the CPU cores is at 1600mhz it shows CPU temp idle to 39-41c but when there is no load just 10-12% the CPU core frequency is at 3700.mhz and cpu temps at 55-60c and using prime95.. shows temps at 65-67c at 100% CPU usage.. using 212 hyper evo with dual fan please help....
Old September 6, 2013, 01:52 PM
Bond007's Avatar
did you try removing the cooler and reseating it? maybe bad contact or bad thermal compound coverage.
Old September 6, 2013, 01:54 PM
I HAVE REAPPLIED THE THERMAL PASTE WITH THE RICE METHOD .. AND ALREADY USING DUAL FAN FOR COOLING.. but iam not getting that when there is no load just 5-12% why CPU core frequency is at 3700.mhz
Old September 6, 2013, 02:35 PM
KaptCrunch's Avatar
add a copper shim between IHS (<same size) and cooler
posiable cooler hanging up on something
Old September 7, 2013, 12:53 AM
Did you set prime 95 to use 1 thread?
Old September 7, 2013, 02:41 AM
i check with prime95 with 1 thread but this time its not going to 3900mhz as it should be... is there some prob with the CPU should i replace it...
Old September 7, 2013, 10:38 AM
http://www.hardwarecanucks.com/forum...retemp-scr.png
Old September 9, 2013, 08:14 PM
Trial Member
Hi new to the board but I thought I'd chime in here
My 3770 with an Asus board I need to have power management set specifically else turbo only ever peaks @ 3700
EIST on
C1E on
C3 off
C6 report on
C7 off
- these settings are the only ones I've found allows max turbo of 3900 using cpuz...
- min proc in power management if using win7 and below needed to be less than 100%... balanced in 8 if min/max not in profile if my memory serves me correctly - this box is now Slackware...
i7 3770 stable or not ? demon08 CPU's and Motherboards 0 September 5, 2013 02:13 PM
is this ram good for i7 3770 k yehia7000 RAM 9 September 9, 2012 10:27 AM
i7 3770 k overclocking problem yehia7000 CPU's and Motherboards 3 July 24, 2012 08:16 PM
CUDA cores vs. Radeon cores Generic User #2 Video Cards 6 March 23, 2012 05:04 PM
8 Intel cores faster than 16 AMD cores? Babrbarossa Rumor Mill 0 May 24, 2007 06:54 AM
