Old August 25, 2013, 03:37 PM
Default cpu is ok or damage....
hye i just recently bought a i7 3770 . . while opening the box i take a good look at the processor when found out there are some lines or or like its was damage .on the ihs (heat spreader) to explain properly posting some pics as you can see at the bottom... these are all on four sides of the processor ... i was worried if the ihs was removed before ..or is it damage . i didn't ordered the mobo as i was not confirm to check cpu or replace it.. please im sharing link for the photos any help will be appreciated
Old August 25, 2013, 03:55 PM
its fine
Old August 25, 2013, 05:54 PM
KaptCrunch's Avatar
its fine have you installed this cpu yet ? if so what are the temps
Old August 25, 2013, 10:48 PM
i didnt order the mobo , becuase i was worried about he cpu .. i also have an e8400 cpu when i double check it there were no sign as i mention above in pics .. sorry for asking this again . but i have bought cpu only 24 hours ago and was little paranoid . should i replace the cpu or continue with this .....
ARE THESE SIGN AVAILABLE ON ALL INTEL CPU!!!
Old August 25, 2013, 11:32 PM
If you purchased the CPU new, contact Intel with the pictures as they would give you a straight answer. From the looks of it, it looks like the solder between the chip and the heat spreader got squished, kind of like peanut butter when you put two pieces of bread together.
Old August 26, 2013, 05:12 AM
great_big_abyss's Avatar
It's just milling marks from when the IHS was machined. Honestly, you're fine. Just order the motherboard, pop it in, and you're off to the races.
Old August 26, 2013, 05:58 AM
Soullessone21's Avatar
What he said
where the flaws are effects absolutely nothing, its like calling apple cuz your iphone 5 has scratches on the side, sure it would be nice if it didnt but once you put a case on no one will ever know and in this case once the heatsink is on you with never notice.
Good Bye HWC it was great :)
Site and Forum:
http://forums.realhardwarereviews.com/index.php
If you need me the link above is where I spend my days now
Old August 26, 2013, 08:58 PM
..thanks for all replies .. i know i was little bit more worried about this cpu because earlier i was having an e8400 but there are no mark available on that ..and yesterday i went to ask the retailer about the doubt i have , he actually replace the processor but when i open it... bang!!! same marks are available on it too... now i have no choice but to continue with this....
Old August 27, 2013, 08:48 AM
trodas's Avatar
Obviously they having bad batch, where the soldering machine that adding the heatspreader is not working as it should. It is just a minor detail, you can run with it hapilly. Maybe even it allow you to remove the heatspreader more easily :)
/where are the times of P3 and P4, where all what was need is a sharp scalpel and patience when working it's way around the chip?
"It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
"I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway :) my config - my caps
Old August 27, 2013, 09:00 AM
That is still all that's really required...well, a razor blade, but still...same idea.
GTX 580 DS with cosmetic damage artistpavel Video Cards 13 August 6, 2011 02:12 AM
CPU Damage, kazman CPU's and Motherboards 17 March 28, 2011 03:03 PM
Rad damage miggs78 Water Cooling 8 August 8, 2010 05:33 PM
how to damage a cpu? magictorch Overclocking, Tweaking and Benchmarking 8 July 28, 2007 08:31 PM
