Old July 11, 2013, 09:29 AM
trodas's Avatar
Question Bios for Sapphire "Grouper" A9RX480 mobo?
Since the absolutely lame Sapphire disable the bios downloads for the A9RX480 there:
Sapphire Technology Web Site
...and tech support did give me the very same link I posted above, so I can't get the BIOS, nor the DOS flasher - not to mention some guide that could be handy, because I feel that only by completely erasing the settings the mobo could post... (eg. visibly post, now it posting and seems working as much, as even blind flash is possible, but NOTHING is on the screen!)
So, anyone can provide me with the Sapphire bios:
PI-A9RX480 BIOS(2K060417)
...and the flasher:
Awardflash(8.63a)
...preferably with some readme on how to get the settings completely erased?
Thanks a lot!
"It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
"I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway :) my config - my caps
Old July 12, 2013, 02:05 AM
trodas's Avatar
Wink
Hoooray, sapphire tech support provided me working link to the latest bios, however no help at all, because this is old bios that I already have:
Hello, tech support!
Thanks for the bios and Awdflash. Unfortunately, this is the bios from 17. 4. 2006, witch can be found even there:
Sapphire "Grouper" A9FX480 bios files
That means I already tried to flash it, yet nothing happend. So, are there any other recommendations how to proceed?
I tried Uniflash v1.40, because it can output log, and it give my this log file:
00:00:51.95: UniFlash v1.40 started: A:\UNIFLASH.EXE -REBOOT -CMOSC -UNLOCK -LOG -E bios.bin
00:00:52.94: Chipset detected: (1002,5950,01) ** (1002,4377,80)
00:00:52.94: Flat Real Mode initialized
00:00:53.99: CMOS size detected: 256b
00:00:53.99: Found DMI 2.3 board info: RX480-SB450
00:00:54.98: System ROM selected
00:00:55.96: Beginning Flash ROM detection...
00:00:55.96: DetectLoop
00:00:56.95: DetectLoop
00:00:57.94: Flash ROM detection complete
00:00:57.94: Allocating memory block 00080000
00:00:58.98: Allocating memory block 00080000
00:00:59.97: Allocating memory block 00001080
00:00:59.97: Flash ROM chip detected: PMC Pm49FL004/3.3V (LPC/FWH)
00:01:00.96: Flash ROM ID: 9D6E,FFFF
00:01:01.95: Exiting UniFlash...
00:01:02.99: Turning off logging, shutting down to real mode
So it is not even clear, if the flash happend or not to me. However still nothing on the display is shown up :(
Please advise.
Thanks.
PS. Also I must say, that this line in autoexec.bat doest NOT work:
awdflash bios.bin /PY /SN /CC /CD /CP /R
...while when I use this line:
awdflash bios.bin /PY /SN /CC /CD /CP /F /Tiny /R
Then in worked and flashed (slowly, as the "Tiny" force the loading during flashing, so, it is slow and /F should snad for: "The key /F enables AwardFlash to reprogram FlashROM with the algorithms of the current BIOS version. If a mainboard peculiarities do not allow applying AwardFlash Writer algorithms, you should use the key /F.") and then rebooted the machine quite well. However, still the display did not kick on. Eg, still nothing on the screen is shown up, witch is the major problem since the beginning.
So I managed the Awdflash to run AND flash the bios into the mobo, however computer, that did not display a thing is simply useless... :(
Of course, there is a positive way to look at it - one did not need monitor, nor graphic card for this thing
Old July 12, 2013, 03:55 AM
KaptCrunch's Avatar
check MB for a cmos write portect jumper and set to disable
in pic,,,, what does jumper say
Old July 12, 2013, 08:18 AM
Dzzope's Avatar
Also, considering it's a 939 socket board I wouldn't expect there to be any bios update from the one you have. Just too damn old.
Random quotes:
AKG: "So please don't piss on people and claim its raining. "
Soullessone21: "Their the only fat bitches I ever want in my wife :)"
DeeraxTheCoolNemo: "I never preSs CaPLoCK I just HiT my keyS so Hard ThEY Crit"
Old July 17, 2013, 04:37 AM
trodas's Avatar
Red face
Not to worry, the jumper in wrong position - no post. In clear position (pins 2 and 3, far to the end of the mobo) it working and clearing.
Anyway, I write that the flashing worked - just with the ANOTHER option
You are right, that Sapphire did not come up with any more recent/decent bios. That is shame, but what can I do...
Moderator on the PC perspective forum told me, that he had the best results with the old bios from 26.9.2005, so I tried to flash it using the Awdflash and it really "helped" - the mobo is now not even posting.
After flashing the old bios from 26.9.2005, the machine just flick 7x fast the led near the CMOS battery and that it is. Then it try to post, yet no post, no image on screen, nothing. And then again the led 7x flick and again it try post and again fail... That way it is much worser, because it is IMPOSSIBLE to flash a new bios now...!
Not even blind flash is possible, when the machine refuse to post.
That somewhat confirm that the bios is the root source of problem AND it seems the older bios is better, by judging that the monitor is getting frequently some signal pulses, so it not go to sleep, instead it showing in cycles the error message about videosignal 0 kHz vertical and 0 kHz horizontal... (Eizo F35 Flexscan)
So, more closer to the root of the issue, but yet still far from any solution at all.
Is there are any emergency bios flash (like the Ctrl + Home for Amibios - but this is Awardbios) or what can I do, to get the PC to work again, like it did well for me before? The "amergency" Award bios require the machine to actually boot, witch is not the case there...
:: BIOSMAN Inc :: AMI BIOS RECOVERY, AWARD BIOS Recovery
Tech support seems to be "really" helpfull:
Sorry that, we would suggest you to upgrade the MB due to even this MB BIOS still cannot help to boot up the MB.
Thanks.
PS. Hoooray! When exchanged the PCIEx gfx card to a PCI one GF2 suxxka, then the machine post (altrough nothing on the screen is shown up) and flashing nicely again! Now that is a improvement! It just beep as it finished the flash! Cool. At least the machine can post and the problem might be in the GFX card then... maybe only a externally powerd graphic card works? Dunno. I must try the old card in there...
PS2. Almost there! Got the machine to display something - finally! By using the old gfx card (even w/o pluged the external power cord!) it nicely show up the logo, allow me to do bios settings and work as it should! W/O a glitch! Now that means, that the mobo is working. It just did not like the MSI GeForce 210 589/1024MHz 512MB DDR2 card for one reason or another. It is a ver. 1.1, and it was tested in another PC and it worked there. No idea why it fail to work now...
Suggested settings BIOS to make the card work?
This damn card refuse to work: http://www.msi.com/product/vga/N210-...=Specification
Meanwhile the board is passing memtest test with no errors twice :) Seems good!
When way more powerfull and way more PSU demanding 7800 GTX works fine then it make me wonder, why MSI GeForce 210-MD512H did not work at all
Some BIOS settings are really interesting - how about to tweak these?
LTD Configuration - Enabled
Upstream LTD Bus Width - 16bit
Downstream LTD Bus Width - 16bit
LTD Bus Frequency - Auto (1GHz, 800MHz, 600MHz, 400MHz, 200MHz)
(I know, this have more to do with the CPU memory controler that GFX card, but who knows?)
PCIE GFX Core Payload Size - 64Bytes (32Bytes, 16Bytes)
PCIE GPP Core Payload Size - 64Bytes (32Bytes, 16Bytes)
NB-SB Port Configuration - Default (Enhanced)
PCI-E GFX Link Width - x16 (x12, x8, x4, x2, x1)
Assign IRQ For VGA - Enabled (Disabled)
...any suggestions? Tried 32Bytes (for the PCIE GFX Core Payload Size|PCIE GPP Core Payload Size settings), but no change. Eg. NO POST with this MSI card...
Old July 17, 2013, 04:42 AM
supaflyx3's Avatar
Why bother? That motherboard is way too old for any modern use.
Old July 17, 2013, 07:56 AM
trodas's Avatar
Red face
Because w/o it, I have to use a old MSI PM8M3-V (VIA P4M800) mobo with a 2800MHz Celeron D 336 (133x21) in it and that is way more crappy hardware that Opteron 148 that can do 2800MHz easily and have far, far more computing power that Celeron D "netburst" crap...
That is why. MSI claims compatibility issue... Any bios fix for that for the GFX card exist?
Old July 17, 2013, 09:37 AM
lowfat's Avatar
Have you seen the board? It is one of the most original boards ever made. I'd love to have one.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old July 17, 2013, 09:40 AM
supaflyx3's Avatar
They also made an AM2+ board with the same design IIRC.
Old July 18, 2013, 01:36 AM
trodas's Avatar
I realized, where the problem is. Since the mainboard Sapphire A9RX480 PCIE slots are version 1.0a, then any graphic card have to be backwards compatible with PCIE 1.0a in order to work. Since there is, in the MSI GeForce 210-MD512H, mentioned only support for PCIE v2.0, then it probably means that it will never work on PCIE v1.0a and hence I need a gfx card, that is backward compatible with PCIE v1.0a...
And this card is not it.
So, unless there could be done a bios tweak, that allow this backward compatibility, there is no way to make the card work in Sapphire A9RX480. Damn!
I still like the mobo!
Seen this? View image: Sapphire A9 RX48 2
Or this? http://s1.postimg.org/a6d0h180f/Sapphire_A9_RX48_3.jpg
...and mind you, these are OLD pics with the BAD CAPS there, that are (on the top of that) - ughly. The new caps looks like this:
That is my picture, that is how the mobo looked AFTER the catastrophic failure with bad caps of pre-production models. They fixed it with good quality Nichicon (even the gold ones - a true HZ Nichicons, witch are the best elyte caps ever made!) caps.
Also a socket 939 is much better alternative that the socket LGA775 and Celeron D 336 (2.8GHz, 256k L2) I run now, so... Give me a better HW and I hapilly run on it. Right now, even getting better CPU for the MSI PM8M3-V (VIA P4M800) looks problematic, as the only 2MB L2 CPUs the v1 PCB of this mobo supports are the Prescotts:
http://www.msi.com/product/mb/PM8M3-...div=CPUSupport
Not to mention Radeon 9100 as graphic card, dude! :D
...so now tell me, that a Opteron 148 that can run at 2,8GHz and up ( CPU-Z Validator 3.1 ) is old CPU :) Sure it is not new. But sure as hell is tad faster that the Celeron D suxxka!
Sapphire 6970 Flex "Need Help" Bill Papathan Video Cards 3 December 26, 2011 01:11 AM
ASUS Bios update with "reduced thermal" Bond007 CPU's and Motherboards 16 September 6, 2011 04:42 PM
Sandy Bridge GPU vs. 1156 GPU vs. Mobo Integrated GPU vs. "Straight Up" GPU ImmaPC HTPC Systems & Software 5 March 16, 2011 04:41 AM
EVGA Releases "Free Performance Boost" BIOS for GTX 460 jcmaz Press Releases & Tech News 1 August 9, 2010 07:21 PM
10 Step "No Post" BIOS Recovery Guide sswilson Guides & How-to's 16 September 24, 2009 04:56 PM
