Old June 29, 2013, 06:04 PM
Question AMD motherboard replacement?
Hello folks, i am new to tech stuff. I used to work an an AMD system built by a friend of mine. I usually like to do audio and video editing. So -- audio quality is real important for me. Are there any recommendations for an upgrade?
My current system is Biostar TA990FXE processor: amd fx-8150 4GB ram ddr3-1333. I badly need your advice for worst thing happens as my system is already years older so I wanna have back up plan based from your experties.
My budget will be more or less 300$
Thank you!
Old June 29, 2013, 06:08 PM
Just to be clear, you're looking to upgrade your motherboard only? Is it dead?
If it still works and you're only looking for better audio, you might want to look at just a good audio card.
Old June 29, 2013, 06:31 PM
Bond007's Avatar
Agree with the above. Are you just upgrading the motherboard for sound or did it fail?
Old July 28, 2013, 09:46 AM
primarily i want to upgrade my whole system, i am not so sure if its wise to change the motherboard or some other components.
I am hoping to get a boost on overall performance. For the beginning i would like to have any input whats usefull from your point of view.
Old July 28, 2013, 09:54 AM
Shadowmeph's Avatar
by performance what do you mean performance in what internet, gaming, programming, Video processing? you could just add another 4 gb ram what is the rest of your system? maybe a video card will work .
Old July 28, 2013, 10:22 AM
The motherboard is already using the top of the line chipset but I don't know anything about overclocking. Even if you upgrade the CPU, you aren't going to get a serious jump in performance. For audio & video editing, 4GB of RAM just doesn't cut it. May be grab a set of 2x4GB and move to 12GB? Try to get the same brand and model to avoid headaches. Also, as the other have said, get a better sound card if audio quality is a priority.
motherboard replacement carme CPU's and Motherboards 1 August 19, 2011 04:45 AM
Replacement motherboard needed! BrutalGreen CPU's and Motherboards 1 June 22, 2011 10:20 PM
Buying A replacement X58 motherboard/Waiting for Sandy Bridge EX???? Badass1982 CPU's and Motherboards 0 March 23, 2011 05:39 PM
broken motherboard? suggest replacement please Socrates_Johnston Troubleshooting 20 August 15, 2010 06:15 PM
[WTB] a replacement Motherboard Shadowmeph Buy/Sell & Trade 6 July 14, 2009 09:30 PM
