Old June 11, 2013, 09:12 AM
10e's Avatar
10e 10e is offline
Default Haswell owners and overclocks
Post your results here.
My results so far have not been satisfactory.
1.29 volts vCore (manually set) and 4.4 Ghz with some stability, though not enough to even run the Intel LinPack binaries with AVX for more than a few seconds without throttling.
My chip's an L311B203 batch, and while users elsewhere have said it's a good batch, but my experience is different, and not very impressive.
Here are links to my results/posts so far:
Intel Haswell i7-4770K & i5-4670K Review Comment Thread
I just started a new thread to see what others are getting. I just can't believe that this chip is so voltage and power hungry.
Last edited by 10e; June 12, 2013 at 07:06 AM. Reason: Added more specific Batch number
Old June 11, 2013, 10:27 AM
Eldonko's Avatar
Hardware Canucks Reviewer
4.9 on both a 4670K and 4770K ES C0 chips that I was told were average at best. High end H20 cooling. Going to pick up a retail shortly and see how it compares.
Old June 11, 2013, 10:51 AM
Sushi Warrior's Avatar
I heard that a few OEM's (Asus in particular) were saying that ES samples did far better than retail chips. 4.7+ on ES, yet most retail maxed out at 4.2-4.4.
Old June 11, 2013, 11:33 AM
Eldonko's Avatar
That's what some people have been claiming but Im not sure on it myself as Ive seen retails clock the same as the ES chips I have. They are both C0 in the end and I doubt there is that much difference. That's why Im going to go and buy my own retail chip to try for myself.
Old June 11, 2013, 02:32 PM
Well, I've been testing my new system for six hours now, and bottom line, I'm disappointed. I can get 4.6Ghz stable, but that's with a high-end water loop and a very high vcore of 1.35v.
With this setup, testing with AIDA, it has run stable for 60 minutes so far... The temps are around 75C, but they can climb enough to trigger a 3% throttle for a second, once every 2 minutes or so.
At 4.8Ghz, the system will barely boot into the BIOS, and at 4.7 I can get into Windows but it isn't stable.
Ring frequency is 4.3Ghz, 1.5v
The CPU won't even boot with a strap of 166, and I didn't notice any improvement at 125. I keep hoping that I'll find some options that will give me a better overclock but so far I haven't found anything.
Old June 11, 2013, 02:37 PM
Eldonko's Avatar
4.6 isnt exactly that bad.. Especially for 6 hours of testing. Ive put in at least 40 hours of testing into this board and chip alone.
Old June 11, 2013, 02:42 PM
Do you have any suggestion as far as things to try? I'm really bad at manual work so delidding is not an option for me (just changing my Heatkiller waterbock from 1366 to 1150 scared me).
I've disabled Hyperthreading and all the low power features, meaning that the CPU always runs at 4.6Ghz and 1.35v even when it's doing nothing. I figure I can always re-enable those options later but it makes for an easier time finding the best overclock...
I'm just not sure what other setting I can try.
Old June 11, 2013, 02:51 PM
Eldonko's Avatar
Reduce mem speed and uncore, find max cpu clock that has reasonable temps. Reduce cpu speed by around 50Mhz and drop voltage as much as possible. Work up mem clocks until you find max stable, repeat with uncore.
I would also use adaptive voltage instead of manual as it saves on temps and power when not fully loaded.
Old June 11, 2013, 03:57 PM
crowTrobot's Avatar
Retail 4770K, 4.5GHz @ 1.265V on Z87 Pro with AIDA stability test. I haven't tested if it is stable with memory over 1866MHz yet, I couldn't get 4.4 stable with the same chip on the MSI G45 board if the memory wasn't on default JEDEC. Dissappointing but I love the low power consumption though.
Old June 12, 2013, 07:10 AM
10e's Avatar
10e 10e is offline
That seems to be the case. My L311B203 sample was not stable at 4.4Ghz at 1.29 volts. After folding@home for 10 hours or so it hard crashed with the famous BSOD 124.
I re-tried those LinX and IBT binaries at stock. They are the problem (for me) as they die at stock settings. They don't crash but they fail within two minutes with an error, so I'm back to using Prime95 for stability testing.
4.5Ghz is a no-go for my sample. At 1.45 the CPU is still not stable even with cache ratio/un-core set at 39. At that point there is almost no reason to go this high on the core when the un-core is negating this extra 100mhz, so I'm back to testing at 4.4Ghz and 39-41 un-core to see how this plays out. The 1.45v vCore setting starts to get my de-lidded unit to the high 80s low 90s and that's beyond my comfort zone.
My CPU's maximum vcore at stock is a rather high 1.25 volts. Strange. My opinion at this time is that it's a hot, hungry retail sample.
Off the top of my head I don't remember my 3770K being this high at stock, as I think a .25 positive vCore off-set resulted in 1.38 - 1.40 max on that chip.
I'm really interested to see how your retail sample goes. Like you said in the other thread, I probably should have just re-sold the chip, but I'm pretty hard-headed that way, as I don't like giving others my problem heh.
I can still use it, just not at a very high speed
Wait for Haswell? icodeit CPU's and Motherboards 17 November 4, 2012 05:48 AM
GPU Overclocks kendallcschm Video Cards 2 September 30, 2010 03:55 PM
Could people put their core i7 batch number and overclocks here. sheepdogexpress CPU's and Motherboards 8 January 16, 2009 04:10 PM
I7 Overclocks matsta31 Overclocking, Tweaking and Benchmarking 5 December 12, 2008 11:18 AM
VR-Zone overclocks 2900xt Core to 1GHz!! Babrbarossa Reviews & Articles from the Web 0 May 16, 2007 02:17 PM
