Old June 4, 2013, 09:31 PM
I wonder how one of these would do in Starcraft 2.
Old June 4, 2013, 11:24 PM
I tried SC2 with an older Llano IGP (A8-3850). 1v1 was playable until armies got maxed, then the frames dropped. I need a minimum of 60fps, so I had to lower the settings all the way to play @ 1680x1050.
When they start using X700+ IGPs, then you'll have something going. But we'll probably have DDR4/5 as a standard by then, which the IGP will need.
Old June 5, 2013, 12:12 AM
lowfat's Avatar
Think I may grab an a8-6600k to replace my i3-3220.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old June 5, 2013, 12:32 AM
EmptyMellon's Avatar
Just curious, what kind of performance (boost) would one get using an AMD's own dGPU along with an A10's iGPU, compared to an nVidia's dGPU; in other words, is there a noticeable "boost" with "AMD Dual Graphics" (A10+HDXXXX) vs. A10+GT(X) XXX (nVidia)? Or is it just marketing BS?
Old June 5, 2013, 02:00 AM
That hybrid xfire thing was stupid. You could pair up some 6550 or so with your APU and get a boost, which I assume you're talking about. But if you just use your APU as a CPU and add a 6850, you'd wipe the floor.
Funny thing was, sometimes it would backfire in certain games, and you'd get worse performance over using the discrete card by itself.
Old June 5, 2013, 05:59 AM
JD JD is offline
Question, would this run BF3 at all? Even at low settings? Resolution wise, let's say 1080p.
There's a guy at work that wants to play BF3 but at the same time he's super cheap.
Old June 5, 2013, 06:28 AM
Soullessone21's Avatar
The 5800K can run at 720P with ok settings as I used my OCed one to do just that on my TV:)
6XXX should do even better :)
Good Bye HWC it was great :)
Site and Forum:
http://forums.realhardwarereviews.com/index.php
If you need me the link above is where I spend my days now
Old June 23, 2013, 10:56 AM
Any more overclocking results for this particular 6800K? Tried it on water yet?
  #19 (permalink)
Old October 6, 2013, 03:03 PM
great_big_abyss's Avatar
Does anyone know if this chip using IGP will run Minecraft AND record on FRAPS without any lag?
Seagate Desktop HDD.15 4TB Hard Drive Review Comment Thread SKYMTL Storage 18 May 25, 2013 11:52 AM
Detailing Richland’s Dual Graphics & GCN Compatibility (Comment Thread) SKYMTL CPU's and Motherboards 4 March 14, 2013 09:58 PM
AMD Richland APU Preview: Trinity Gets a Facelift (Comment Thread) SKYMTL CPU's and Motherboards 4 March 12, 2013 06:59 AM
AMD A8-3850 APU Review: Llano Hits the Desktop Comment Thread SKYMTL CPU's and Motherboards 58 October 5, 2011 01:54 PM
