Old June 4, 2013, 01:51 PM
Default 1035t upgrade
I havent been able to luck out on grabbing a used 2500k/3570k for my upgrade and i was wondering if theres anything amd currently has right now thats going to make it worth shelling out some coin for an upgrade. i've looked at the fx 4100/6300 and the 8320 but i just dont know enough about amd's newer line of cpu's. Also i would like know how much of a performance gain i would obtain from ocing either of the above 3 mentioned and if it would warrant a cpu/mobo upgrade compared to just forking out for a 3570k ?
Old June 4, 2013, 02:11 PM
great_big_abyss's Avatar
What motherboard do you have?
If you have already have an AM3+ motherboard, you should be able to just drop in an 8350 and actually see a fairly significant performance boost over your 1035T in all applications. If you don't already have an AM3 motherboard, I would keep looking for a good deal on a 3570K and a decent Z77 motherboard. You can catch them sometimes for about $340 new for a processor/motherboard.
Old June 4, 2013, 03:05 PM
any thoughts on the fx 6300 and ocing it? what sort of performance increase will that net over my 1035t
Old June 4, 2013, 04:57 PM
is a brand new 2500k for 180 worth grabbing? thinking if picking it up in the next hour or so
Old June 4, 2013, 06:13 PM
supaflyx3's Avatar
Yes it is.
Old June 4, 2013, 06:58 PM
Send a PM to the guy in this thread:
Z68 V pro and 2500k
He's selling a 2500K and an ASUS Z68-V Pro for a decent price.
EDIT: Rather WAIT until he posts the thread in the BST, then send him a PM.
Old June 4, 2013, 08:02 PM
What's your budget man? You obviously have something large if you're considering changing motherboards as well.
Old June 4, 2013, 09:33 PM
budget isnt really the problem, its more or less saving where i can so i can sli 2 cards to go along with my new benq monitor. If there was a budget i'd like to say something along the lines of 225-250 shipped for a non abused 2500k/p68 and maybe 275-325 shipped depending on the mobo for an ivy brideg equiv
Looking to upgrade and need some help with the MB Mishtar New Builds 7 October 28, 2011 12:09 PM
Should I upgrade my cpu for BF3? biggyk CPU's and Motherboards 14 September 29, 2011 06:40 AM
what to upgrade? peasofme Video Cards 14 August 26, 2011 07:52 PM
VGA upgrade from GTX 260 first, or CPU+mobo upgrade first? panzerfan Video Cards 9 April 6, 2010 08:25 PM
Cpu, Gpu or what? upgrade? phil3_66666 CPU's and Motherboards 12 March 14, 2009 05:54 PM
