Old June 2, 2013, 01:56 PM
Default Haswell : expensive motherboards become even more useless? (or less useful)
Now that most of the VRM are built into the CPU,the "overclock certified" motherboards will have even less impact on the performance,what do you think about it?
Of course,for the extremes,an expensive motherboard will be needed,but i'm wondering if they will make 400$ mobos that just have the bonus to have integrated wifi and good sound card...
I bet you will be able to overclock a 4770k at 4.8 ghz with a 150$ mobo.
Old June 2, 2013, 02:00 PM
sswilson's Avatar
I doubt those two things would be that much of a selling point as the folks who would pay the extra bucks for those features are going to want dedicated cards that they can change out if requirements / specs change.
Old June 2, 2013, 02:22 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
No. The marketing shenanigans will continue.
Old June 2, 2013, 03:31 PM
There are more than enough people who buy expensive hardware without researching to see if they actually benefit from any of the features vs buying a slightly cheaper one, so you know...
Old June 2, 2013, 03:37 PM
Eldonko's Avatar
Hardware Canucks Reviewer
A board's VRM is 1 feature of many and although it may sound like it is no longer important, it is..
Old June 2, 2013, 10:57 PM
It's always been my philosophy that expensive motherboards are for people that love playing WITH their computer (as opposed to playing ON the computer).
I am one of those tinkerers. Of course I need 7 fan headers and 6 temp probes on my motherboard. A coffee maker wouldn't hurt neither....
Old June 3, 2013, 05:10 AM
Roflmao
Old June 3, 2013, 05:51 AM
Dzzope's Avatar
That new asrock board could probably heat your coffee for you... step in the right direction?
Old June 3, 2013, 12:45 PM
NSdeadly1's Avatar
I thought i saw a review of a Z87 board that had replaceable op amps for the onboard sound. Forget which one though.
Old June 3, 2013, 12:47 PM
Slik's Avatar
Anything and everything is important. No such thing as overkill.
EVGA DG 87 -i7 5930k @ 4.4ghz. Liquid cooled-4x4gb G Skill Trident X DDR3@ 2400mhz- EVGA x 2 1080 Ti Black SLI - Soundblaster X7 Sound Card- LG 34" Monitor-ATH AG1X Headphones-Butt Kicker Gamer-TrackIR 5
X-firing in X-Plane is useless fortkentdad Gaming 1 March 17, 2013 10:13 PM
Totally useless fact... Grampa Off Topic 8 November 26, 2011 07:22 PM
Hotmail is useless!! Cadence Off Topic 19 March 2, 2010 08:10 PM
Useless Thread loath Off Topic 1 January 20, 2008 07:02 AM
