Old May 3, 2013, 06:53 AM
Default Need help picking a CPU and mobo
Hello Everyone,
Right now I am at the point where I am looking to get a new CPU and mobo. With all the new CPU's out there I am confused on what to get. The computer is 95% used for gaming (WoW, SC2) and I do a little bit of media streaming to my PS3 (tv shows & movies). Here are the stats of what I have right now:
AMD Phenom II X4 810
Asus M4A785T-M (mobo)
Patriot 1600LL Series RAM - 4x4GB
NVIDIA GeForce GTX560
OS Drive - OCZ Agility3 SSD
Gaming Drive - OCZ Vertix2 SSD
Storage Drive - Sata 2TB Hard Drive.
I am pretty happy with my RAM and video card and looking to get some extra performance out of my rig. I am like most gamers and want to have everything running top notch. I am open to both AMD and Intel and cost is somewhat of an issue.
Thank you for all the recommendations which you guys will (hopefully) give me.
Cheers!
Old May 3, 2013, 07:09 AM
great_big_abyss's Avatar
You say cost is somewhat of an issue...but what is your budget? $200? $300? $400?
For about $400 you could get a nice i5 3570K with z77 motherboard
For about $300 you could get an FX8320/M5A97 combo
For about $200 you might be able to find a used 1090T and pair it with a new M5A97
Old May 3, 2013, 07:14 AM
Canada Computer has this bundle for sale:
Gigabyte GA-F2A85XM-D3H Socket FM2 AMD A85X Chipset Motherboard + AMD A8-5600K (100W) Quad-Core Socket FM2 APU Bundle | Canada Computers
Is it a viable upgrade?
When it comes to cost it's all about convincing the wife.
Old May 3, 2013, 01:10 PM
AlienIsGOD's Avatar
an APU isnt really an upgrade. Save a little money and get a i5 and a z77 mobo.
Gaming Rig (Gaming Cruncher): i5 3570K @ 4.2ghz, Sapphire RX 480 8GB, EVGA Z77 FTW Mobo, 8GB Mushkin Blackline DDR 3, Kingston SSDNOW V300 120GB | 1000GB Data, EVGA SuperNova 750w 80+ Gold, NZXT 810 Switch case
24/7 WCG Cruncher: i5 2400 @3.4ghz, Gigabyte HD Saphire 6870 1GB, AsRock Z68M/USB3 Mobo, 8GB HyperX DDR 3, 120GB HyperX Blue SSD | 1TB storage, CoolerMaster G750M 80+ Bronze, Thermaltake Soprano Snow Edition case
Old May 3, 2013, 01:35 PM
BlueByte's Avatar
Just to throw an in between for a price point.
FX-6300 $149.34
GA-970A-UD3 has better power system 8+2 phase vs the 4 phase on that asus board. $99.99 w $10mir
$239.33
Add a Antec H20 920 $69.99 with the savings and OC that puppy to 4.6Ghz and call it a day.
Total with cooler $319.32
Or wait until the NH-D14 go on sale for $50 to keep it at $300.
Old May 26, 2013, 01:51 AM
If you were trying to save the the CPU by getting an older gen., at least get a phenomII x4 955, they only ~10 more than a 810 and were a very popular chip.
And you DO NOT get that ram for gaming, in most all games 4GB is still just enough, but 8GB is a better choice for the future. So I'd get 4 or 8GB of at least 1600, but 1866 or 2133 is even better if you could afford it. GSkill has some nice quality ram, and fast ram for a good price too. What ever you do just don't get 16GB of slow ram, you will never use 1/2 of it and by the time 16GB is needed for game, it will be WAY too slow by future standards.
And don't cheap out on a power supply, a lot of cheap PSUs are crap, NOT to be trusted with your investment, a fairly good quality 500W PSU can be had for $60.
Not long ago I was looking for a 500W PSU on a budget and read a bunch of reviews, and would advise AGAINST
-Corsair CX400, or 500 (both had bad HardwareSecrets and Johnyguru reviews, and fairly high failure rates it seems)
-most anything cheap from ThermalTake near 500W range
-most anything cheap from coolermaster near 500W
They have some nice ones but not their budget ones, at least not for a worried gamer like me
Most cheap PSUs can't put out their "rated" wattage
-they might be rated for 500W but barely put out 400W before catching fire, etc
-have really bad voltage regulation, can't keep the voltage within 120mV of spec, I like to keep it really clean by keeping it AT MOST within 50mV, your mobo and GPU will love you
I ended up getting an XFX pro 450W for like $64 all inc. from DirectCanda. There really was next to nothing of quality any cheaper (at regular price)
i7 2700k - 7950 3GB crossfire - 4GB 1866 CL8 - 1600p
Old May 26, 2013, 02:10 AM
Dzzope's Avatar
is that ram DDR2? If so it won't fit in most of the options being suggested.
Personally I would go z77 (or z87, once chips start being released for it) and drop in an i3 to keep it cheap.. then in ~2 years drop in an i5, 2 years after that get a decent custom cooler (second-hand even for the chip or coolers) and oc it.. when you then need to replace again in 5~ years, do it again...
Old May 26, 2013, 02:18 AM
For what you currently do with your PC, I wouldn't even bother upgrading. You will not see a large or noticeable difference by upgrading the CPU.
Upgrading your video card will yield much more FPS in the games you play.
Help picking a GPU wbartlebaugh Video Cards 10 December 28, 2012 09:27 AM
Need Help picking up RAM Wurmer RAM 1 March 12, 2010 02:31 PM
Help picking a GPU xghostz Video Cards 42 October 14, 2008 06:27 PM
Help picking ISP Dar_ell Off Topic 14 August 11, 2008 04:41 PM
FS-s939 X2-3800, OCZ ram, Ac Freezer 64 Pro, ASRock mobo, DFI mobo, Asus mobo..more stoanee Buy/Sell & Trade 14 June 7, 2008 06:24 PM
