-   -   Asus p6t sli question (http://www.hardwarecanucks.com/forum/cpus-motherboards/60319-asus-p6t-sli-question.html)
DBGP March 21, 2013 06:21 PM
My main question here is this. Right now im running 3 gtx 570's on my asus p6t (not deluxe,) but lets rewind a bit. Before i was only running on 2 570's which are water cooled, then i was able to squeeze the third one in the middle which had the stock air cooler. The motherboard came only with the 3way sli bridge. My question is that before i was running sli having the cards in the top and bottom slots, but would i be able to sli it with one card in the top and one in the middle slot, leaving the bottom free? So in this case if i want to get rid of my third card it doesnt involve me ripping apart my water cooling. The 3 slots are all pcie 2.0x16. I was thinking of maybe swapping to a new case and was going to place the cards differently.
And on a side note, when i was using only the 2 cards, i had 6 2gb of corsair dominator ram, but since i added the third card, the computer will only run if i have 3 sticks of ram installed. Whats going on there? Thanks guys
ZZLEE March 21, 2013 07:01 PM
Yep and Yep.
The top SLI slot will Run 16 X
The middle 16X slot may run at 8X but that shouldn't be to much of a problem.
Look in Motherboard book it should tell whats up.
4 gig sticks are nice 3 of those you got 12 gb. make sure to leave a space between each stick. when you install ram and you should get triple channel.
DBGP March 21, 2013 07:50 PM
I have spaces between the ram. Any idea why 12gb won't work with 3 video cards but will with 2? The box and book are long gone but il look online for a manual
