Old March 16, 2007, 05:46 PM
Babrbarossa's Avatar
Default Bab's Recommended best - value components
Case Antec p180 $141
Mobo Gigabyte GA-965P-DS3 $161
Mobo Asus P5N-E Sli Nforce 650I $156
Mobo Asus p5b deluxe $240
Mobo EVGA Nforce 680I SLI $262
PSU OCZ GameXStream 600W $110
RAM OCZ Platinum PC6400 4-4-4-15 $195
RAM Patriot Extreme Performance 2GB 2X1GB PC2-6400 DDR2-800 CL5-5-5-12 $210
RAM Mushkin XP2 PC2-6400 2GB 2X1GB DDR2-800 CL 4-4-3-10 $294
RAM G.SKILL F2-6400PHU2-2GBHZ PC2-6400 2GB 2X1GB DDR2-800 CL4-4-4-12 $297
H.D. Seagate Barracuda 7200.10 320GB $99
GPU EVGA 8800 GTS 640MB $440
CPU Intel Core 2 Duo e6300 $224
Make sure when choosing RAM that you check for compatibility with your motherboard.
Old March 16, 2007, 05:53 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Ugh....get that P180 out of there.
Old March 16, 2007, 06:03 PM
I expected you to kybosh the ocz psu too-
Old March 16, 2007, 09:18 PM
BALISTX's Avatar
What, no memory?
Heatware
HWBOT
Old March 16, 2007, 09:26 PM
SKYMTL's Avatar
Nah...for $110 the GameXstream 600W is the best PSU for the money without a doubt.
Old March 16, 2007, 10:55 PM
I thought i did put memory in- it's there now- ocz platinum- not the fastest but the best for the dough
Old March 17, 2007, 06:22 AM
Patriote's Avatar
Add some Ram kit using Micron D9s that can Oc like and we're all gonna be happy
- Asus P8Z68-V PRO
- Intel I5 2500k @ 4.5Ghz
- Asus Geforce 580GTX DirectCUII Fermi
- 16GB Corsair Vengeance Low Profile
- Ultra X3 1000 Watt
- Asus Xonar DX 7.1 \ Klipsch Promedia 2.1 THX
- Corsair Vengeance 1300 Gaming Headset
- Crucial M4 SSD 128GB \ WD Caviar Black 1TB
- CoolerMaster 690II Advanced
- Dell UltraSharp 24''
- Noctua NH-D14
fitting PCI components on a Motherboard tom.mullie CPU's and Motherboards 2 February 9, 2008 07:07 PM
best components for the price for a HTPC hidef HTPC Systems & Software 1 October 4, 2007 08:19 AM
My new components keenan CPU's and Motherboards 10 August 12, 2007 11:36 AM
soundcard recommended? enzeo Peripherals 5 June 27, 2007 10:14 AM
Bab's 1000th post Babrbarossa Off Topic 7 April 10, 2007 09:45 PM
