Old January 30, 2013, 12:57 AM
Silvgearx's Avatar
Default Core 2 duo/Athlon II vs Sandy/Ivy Dual cores?
3.0 sandy/ivy vs 4ghz C2D 2mb cashe/ Athlons IIs
Gonna be using a gtx 260 or GT520
The G860 caught my eye for $60.
Old January 30, 2013, 04:58 AM
you might want to get a clearer picture installing Performance Test version 7 and then comparing the results you can download online, but from what I have seen, the Pentium G2120 at 3.1 GHz was about 25% faster than a Core 2 Duo at the same frequency.
Old January 30, 2013, 07:51 AM
If you were on a tight budget starting from scratch you could definitely use the g860 (and I would suggest it over buying old tech). If you already have the c2d/athlon running at those speeds I would just keep it until you can jump to a higher end cpu. Here is a graph of c2d e8600 vs pentium g850...they are comparable in everything (though the g850 is a touch faster in most instances, except power consumption where it uses substantially less).
AnandTech - Bench - CPU
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old January 30, 2013, 08:54 PM
Silvgearx's Avatar
Thanks for the charts, I think I use the g860 since its hard to find a matx lga 775 overclocking board. And since I already have an amd 785gm rig.
Old January 30, 2013, 10:11 PM
Good call. Going with a g860 also gives you the option (if funds permit at some point) a drop in solution to go to an i5 and see substantial gains, whereas 775 is a dead platform.
Intel Sandy Bridge Core i5-2500K & Core i7-2600K Processors Review Comment Thread SKYMTL CPU's and Motherboards 52 November 6, 2011 08:21 AM
Windows xp sp1 doesn't notice dual cores. andynerd Troubleshooting 9 December 28, 2008 08:03 AM
LF: AMD Athlon Dual Core (S939) Lpfan4ever Buy/Sell & Trade 25 October 15, 2008 03:15 PM
Orientation of Apogee GT for dual cores? sswilson Water Cooling 3 May 17, 2008 06:17 PM
