-   -   Onboard GPU (http://www.hardwarecanucks.com/forum/cpus-motherboards/59195-onboard-gpu.html)
nasrott January 17, 2013 01:50 PM
Onboard GPU
Hey guys was wondering if the onboard gpu on a 3770k can play 3d video on my asus 3d 120hz monitor? Believe the onboard only does 60hz so was wondering if it worked idea?
JJThomp January 17, 2013 09:49 PM
Definitely will not do 3d.
P.S where you from in Newmarket? I live on Bexhill.
OC-Guru January 17, 2013 10:17 PM
As far as I'm aware.. intel integrated GPUs do not support 3D.. only 2D displays.
nasrott January 18, 2013 01:56 AM
Thx guys was hopeing something had changed on the new cpu.'s.
Ya been in NM for awhile now,
Ya your not too far away, am over on Huron Heghts.
OC-Guru January 18, 2013 02:58 AM
you could pick up a cheapish card that could handle the 3D display though. :)
nasrott January 18, 2013 03:02 AM
How would that play with my 7970 I have now? Have lots of room on my board for sure...
supaflyx3 January 18, 2013 03:26 AM
You'll need a nvidia GPU for any decent 3D play.
OC-Guru January 18, 2013 04:16 AM
it'd be worth throwing it in your rig :)
