-   -   ASUS P8Z68-V LX problems (http://www.hardwarecanucks.com/forum/cpus-motherboards/59027-asus-p8z68-v-lx-problems.html)
dukesdad January 8, 2013 01:47 PM
I know it's kind of a cheap board, but it was all Tiger Direct had left on the shelf Boxing Day 2011.
That said, it's been fine until about 2 weeks ago.
2 of the rear USB ports have stopped working. The only thing I've used them for is a new Logitech wireless keyboard and mouse.
About the same time I started getting a message that the driver for my XFX 6850 had stopped working. Screen would go blank, then come back in about 15 seconds. Reinstalled the driver, same problem.
This is all after installing windows 8 about a month ago.
Is there a chance these problems are software related, or is it a crapped out motherboard?
Don't think its heat related.
Intel 2600k
XFX 6850
Corsair 750 watt power supply
8 gb Corsair Vengeance ram
Corsair H60 cooler
OCZ Vertex 3 SSD
WD Black
Rosewill Destroyer case
ZZLEE January 8, 2013 02:58 PM
go to asus and dounload latest driver fore the board Intel and USB divers.
Look fore latest drivers fore mouse and keyboard.
software fore Keyboard and mouse.
try that first .
dukesdad January 9, 2013 06:47 PM
Solved
Updated the Bios and all is well. For Now.
Definitely keep my eyes open for a better board.
I should know better than buy a $125 board, with a $1000 dollars worth of equipment depending on it.
ZZLEE January 9, 2013 11:37 PM
Look fore a Maximus IV
where do you live ??
Look fore a cheep but good 1155 board :biggrin:
Falcy January 12, 2013 02:33 AM
It may be a cheap board but things like USB-ports and that "basic" stuff is almost the same even on expensive boards.
I have the Z68-V LX myself and i am very pleased with it. Could never imagine it would overlock this good.
I run my i5 2500k 3.3Ghz @ 4.7Ghz, fully stable with prime95 @ 1.360v. Load temp with prime95 are max 80() degrees celsius with air. I use the Noctua U12 cooler.
(Sorry for bad english, i am from Sweden) :)
