-   -   hardware break in best practice (http://www.hardwarecanucks.com/forum/cpus-motherboards/58902-hardware-break-best-practice.html)
guilly January 3, 2013 01:55 PM
I'm in the process of finishing my first gaming rig and was wondering if anyone has any recommendations to "break in" my hardware ? From what I've been reading some people will leave there systems running for 48 hrs, are there any applications I should run to stress test the hardware ?
Thanks
dandelioneater January 3, 2013 02:18 PM
I guess if you really wanted to stress test the system you could run prime95 to test the cpu and maybe run a game for the video card or msi kombustor.
Another option would be to do some "Folding @ home". That will stress the system for sure.
tangrisser January 3, 2013 02:56 PM
It's not 'best' but Futuremark's PCMark or 3DMark is commonly used.
SugarJ January 3, 2013 03:35 PM
I tend to use OCCT or Prime 95 to stress test a CPU, and Furmark or Kombustor to test a GPU. If it passes those, then I throw on Folding @ Home for 24 hours. If there's no errors after 24 hours of Folding, it's stable.
Edit: This has links to all the software mentioned except the folding. It's available at folding.stanford.edu
http://www.hardwarecanucks.com/forum...ols-trade.html
