-   -   MB to replace ASUS P8Z68D (http://www.hardwarecanucks.com/forum/cpus-motherboards/58800-mb-replace-asus-p8z68d.html)
Ampersand December 29, 2012 10:19 PM
My ASUS P8Z68 Deluxe is refusing to POST (VGA LED lit and Q-code 06 if anyone has magic fix). I'd like to get a replacement board while I try to fix it. It's been a while since i've kept up with motherboards, so I'd like suggestions on what would be a good deal.
Stuff the new board needs to take:
i7 2600k
Koolance CPU-370 waterblock (closed loop)
4x4GB 1600 MHz ram
6970 x2
PCI wifi card
OCZ Vertex 2
misc SATA
OCZ Z1000M PSU
The case size is 1 slot taller than the current board.
Thanks in advance.
altereDad December 29, 2012 10:55 PM
Temp replacement??? Check the RAM specs to confirm. Should handle it
Gigabyte B75M-D3H mATX LGA1155 B75 DDR3 2PCI-E16 2PCI HDMI CrossFireX SATA3 USB3.0 Motherboard
Ampersand December 30, 2012 09:49 AM
Great reviews on that board. Thanks!
botat29 December 30, 2012 10:25 AM
or get a MSI Z77A-GD55 and sell the Asus when it come back from RMA, MSI is so advance compare to non ROG board, I can even control and OC the board from my Android or Iphone.
Newegg.ca - MSI Z77A-GD55 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
sf101 December 30, 2012 07:13 PM
if you cant think of any physical damage sometimes unplugging power removing battery and shorting the battery connections for a bit will give your bios a solid reset.
but if something else is a miss like pop caps or physical problems then ofc that wont help you.
Ampersand December 31, 2012 07:57 AM
This board is OOS wherever it's on sale! That means it's pretty good I think. Thanks.
I think something went wrong during a BIOS flash. CMOS reset (button not jumper) doesn't seem to help at all. Does taking out the battery have a different effect ?
KaptCrunch December 31, 2012 09:21 AM
Hoped that you removed the power cord and press start button before when reset cmos and replaced back 1-2
Q-code 06 which means "Microcode Loading"
reseat cpu (and cmos chip if is sockect mount) and RAM or try 1 stick of ram
Ampersand January 4, 2013 10:46 AM
I've given up trying to fix and am considering BIOSTAR TZ77XE3 or MSI Z77A-G43 both at $100.
I'm worried that the bottom edge connectors will be obstructed by the 2nd graphics card. Otherwise I'd get this board. Thanks again for the suggestion.
GD55 feels like more features than I really need atm. G45 has no PCI slots, which I need. I am considering a G43. Thanks.
