  #71 (permalink)
Old February 10, 2014, 03:17 AM
nasrott's Avatar
The is an aquarium chiller a few of the boy's were looking at awhile ago. Fittings could be moded to a couple of disconnects.
  #72 (permalink)
Old February 10, 2014, 06:44 AM
Shadowarez's Avatar
Thatd be interesting for a mitx build modify the fridge cooling and you can get a nice subzero cooler. Just wish phase changing would evolve to include cpu coolers for less then $4500 a piece.
  #73 (permalink)
Old February 10, 2014, 07:43 AM
lowfat's Avatar
Most mini fridges will not work. The compressors will not hold a load. They will burn out. A CPU single stage isnt anywhere near $4500. They will definitely be under $1000.
Mael
Big Lian Li
Forever Alone
  #74 (permalink)
Old February 21, 2014, 03:09 AM
nasrott's Avatar
vaporchill still making cases lowfat? Or was it promethia, one went under cant remember now which.
  #75 (permalink)
Old June 27, 2014, 05:50 PM
Welp.
Just did a fail de-lid.
- Damaged heat spreader: I tried vice method with no luck. The edge just curled up on itself like a wave, so I filed it down. (Sorry, no before-filing pics).
- Gouged the PCB: as I was cutting the IHS off, I knick a corner with my blade. I only notice after it's carved a little bit of green out. I swap blades and get the job done.
- Won't POST: After a quick cleanup and re-tim with Ceramique, I pop it in. It won't post. Boot loop power off. I thought I killed a chip, but I remembered... I had painters tape on the bottom as a 'leash' for the vice method. Decided to clean off the residue from the bottom of the chip.
- It's ALIVE!!!: It's alive, but instead of Linpack @ 100C, it is now a nice and icy 95C. WTF??
- Concave IHS: It's concave as hell.
- Should have noticed before I started it all, because this was with the stock CPU:
tldr; De-lidded 4770K. Shaved 5C off of 100C @ full load.
heatware
  #76 (permalink)
Old June 27, 2014, 05:56 PM
Sagath's Avatar
Holy!
That CPU looks like a prime candidate for the no IHS watercooling mod from EK! ;)
I dont bother with the vice method. I'm not a fan of 'brute force' method. Vices arnt ment for electronics...
  #77 (permalink)
Old June 27, 2014, 07:27 PM
MacJunky's Avatar
Zoob, I want to suggest that you lap the IHS, but in reality that did not do very much for me. I just got the naked mounting kit for my Supremacy installed and my max temp went from about 90c to mid-70s. (I gained around 10c during summer, if you are wondering why I said 80c previously in the thread)
Is the mounting hardware of your waterblock capable of going tighter after IHS and retention bracket thingy removal, or do those screws bottom out too soon?
  #78 (permalink)
Old June 27, 2014, 09:07 PM
Goddamn must be doing something wrong. I just lapped it down to copper and still hitting 100C.
I have a Swiftech H220 and I wouldn't trust mounting that POS to a naked die. I have enough trouble mounting it as is with a heat spreader.
It all looks ok to me?? Maybe this ASUS board is doing some weird AUTO voltage garbage when I have it on 40X multi?
Took forever to lap since I only have 220 grit at the moment.
EDIT:
I set everything to stock besides my RAM OC @ DDR3-2200, VRAM 1.625, and VCCSA +0.035 and it still hits 80C load in LinX
37x100 @ 1.182V in CPU-Z (auto multi/auto voltage/etc/etc)
EDIT 2 :
Everything bone stock gets me 70C in LinX load.
EDIT 3 :
With Sync all cores enabled I get 89C load.
Fan speed (H220 fan + pump) is set to auto "turbo" mode in QFan.
Gonna call it a night and work on it with a clear head tomorrow.
heatware
  #79 (permalink)
Old June 28, 2014, 04:17 AM
KaptCrunch's Avatar
looks to me that the water block is the issue for seems its has a hollow spot in center is convex
re-surface block on a sheet of glass or take off outer edge to rid of low spot in center
then use a straight edge to check flatness , really want a concave surface
where in Toronto? Active Surplus Electronics pick up a copper sheet to use as shim between block an speader
  #80 (permalink)
Old June 28, 2014, 07:24 AM
Thanks for the input. I've put a line of thermal paste down the middle and that was the imprint it left.
I'm fine with my block being convex to push all the paste out from the middle (where the core is).
It's most likely just a combination of bad chip and overzealous voltages coming from my ASUS Z87 Deluxe.
I manually set it to 40x100 1.175V and I get around 80-82C LinX full load. 42x100 1.25V hits 86C and is not stable.
Does anybody in GTA east have a bench setup for naked mounting and would be willing to help test my chip? :|
heatware
i7 920 to i7 3770k worth it? OpTioN CPU's and Motherboards 12 December 17, 2012 07:47 PM
I7 3770k only an Ivy Bridge? Zaraydis CPU's and Motherboards 2 November 20, 2012 04:23 PM
I7 3770K Your_friendly_gamer Price Check 2 October 6, 2012 11:37 PM
i7 3770k or i5 3570k netgears CPU's and Motherboards 9 July 9, 2012 09:58 AM
Tempted by the dark side lcdguy New Builds 18 November 4, 2011 04:37 PM
