  #51 (permalink)
Old July 9, 2013, 10:04 AM
Coach's Avatar
Originally Posted by KaptCrunch View Post
OTHER METHOD is to bring CPU lid to -20c then it should pop off eazy with wedge of thin blades
I had not heard of that one. IMHO the method I used was so easy to perform I would not consider another method at this point.
  #52 (permalink)
Old January 14, 2014, 05:19 PM
Sagath's Avatar
Necro-Bump for new Haswell users!
I just did this with my new 4770k. Took 5 min. I used an exacto knife on a corner, then following advice about using a hard plastic thin card, shoved that in a corner and went all the way around the IHS. Blam! 5 min, IHS was off. 5 more min to clean everything and reapply TIM (IC7 Diamond on die and on IHS).
Idle temps went from 30c (Under WATER) to 23c @4.5ghz 1.2v
Load temps went from 91c to 77c at the same speed/volts.
Woooooow.
  #53 (permalink)
Old January 14, 2014, 05:21 PM
sswilson's Avatar
Damn, that's a pretty impressive improvement. :)
  #54 (permalink)
Old January 14, 2014, 05:26 PM
nasrott's Avatar
What were u using to get your load temps
  #55 (permalink)
Old January 14, 2014, 05:30 PM
Sagath's Avatar
Stress test under Linpack/Intel Burn test
Got temps via Speccy
  #56 (permalink)
Old January 14, 2014, 06:02 PM
Nice! Order that CL Liquid Pro next :)
heatware
  #57 (permalink)
Old January 14, 2014, 06:21 PM
Bond007's Avatar
That is an impressive improvement. Going to push the OC more now with the temp drop, or are you happy as is?
  #58 (permalink)
Old January 14, 2014, 06:34 PM
Sagath's Avatar
Probably hold back right now. My 2700k was @4.5, so I'm already well above the curve on performance. Im going to pick up the CL Liquid Pro and reseat the die/ihs and the waterblock with them first.
Zoob: How many tubes should I scoop? Dont know how long this stuff lasts or how far it goes. My IC7 Diamond has lasted me years...
  #59 (permalink)
Old January 14, 2014, 06:41 PM
One tube should be fine. I have de-lidded 4 chips and still have plenty of Liquid pro to spare.
heatware
  #60 (permalink)
Old January 14, 2014, 07:00 PM
MacJunky's Avatar
^^ Basically what Sagath said, except I used the vice method for my 4770k last year.
The temps are still pretty horrific though, might have to ditch the IHS.
Before I added a 7950 to my loop.. with EK Supremacy & feser 480 rad the water temp could be cold to the touch yet the CPU is up at 60C
Since adding a 7950.. while loading both, the 7950 can be 20-25C and the CPU pushing 80-85C.
That is with Antec Formula 7 on the GPU, CPU, and CPU IHS. As said above, dumping the IHS sounds like the only way I am going to do better.
Though in all fairness I am up at 1.4v.... Technically I do not have to run it at 4.7GHz 1.4v. but if I drop below 4.6GHz then I am no longer hitting 10.XXpts in cinebench r11.5! :<
Anyone have a non-leaky TFC 480 rad they want to get rid of?
i7 920 to i7 3770k worth it? OpTioN CPU's and Motherboards 12 December 17, 2012 07:47 PM
I7 3770k only an Ivy Bridge? Zaraydis CPU's and Motherboards 2 November 20, 2012 04:23 PM
I7 3770K Your_friendly_gamer Price Check 2 October 6, 2012 11:37 PM
i7 3770k or i5 3570k netgears CPU's and Motherboards 9 July 9, 2012 09:58 AM
Tempted by the dark side lcdguy New Builds 18 November 4, 2011 04:37 PM
