<~----> 3770K owners tempted to delid - Page 2 - Hardware Canucks
Old December 19, 2012, 11:20 AM
otherwise he would run risk of crushing the chip which some people have done.
My 3 current rigs
guest - Main - Work
I7 930@4.0ghz
3770K@ 4.8ghz
2500k @ 4.7ghz
SF101 HW BOT
Old December 19, 2012, 11:32 AM
Phill's Avatar
I think I will try to glue the IHS back on to the pcb of the cpu. I do not think other de-liders generally do that but I would like to try.
Old December 19, 2012, 12:24 PM
I always do a cost benefit and risk analysis before doing something, seems to me the cost benefit isn't there in relation to the risk you are taking on.
Old December 19, 2012, 12:26 PM
Perineum's Avatar
Well according to that thread you posted it's the removal of the glue and therefore the change in spacing between the IHS and CPU die that is causing the temp difference.
Old December 19, 2012, 01:01 PM
I kind of gathered the same message, but I wouldn't doubt that changing the composition of the paste to something that better transfers heat makes a difference as well.
Old December 19, 2012, 01:06 PM
botat29's Avatar
Originally Posted by IRQ Conflict View Post
Is 200Mhz really worth the risk? Those things are over 300 smackers. When I get mine I plan to park it at about 4.5-4.6 for a dedicated gaming rig. Don't want to tempt fate.
For $ 25 you can get the "Performance Tuning Protection Plan " of Intel, I wonder if they will replace it if you remove the IHS
http://click.intel.com/tuningplan/
Old December 20, 2012, 01:17 AM
elmorejohn46's Avatar
I do not think they ment the plan for ripping off the heat shield ,I think it is just for overclocking the heii out of it.Unless you can put it back on and it is not noticeable.
Intel-i7-3820+Corsair H-100+Gigabyte X79-UD5+16g G.Skill 1666DDR3+256g Crucial-SSD+1-3TB Seagate+2-1TB-Samsung+1-640g- WesternDigtal+SLI-ASUS DIRECT CU II GTX-670+LG-12x Blurner+Logtech G9x-mouse+G-110-keyboard+Driving Force GT Wheel+Pioneer VSX-1020K+Polk Audio Speakers+LG-50"Plasma PM6700+Antec-P280+XFX 850w PRO Semi-Modular
Old December 20, 2012, 01:20 AM
Perineum's Avatar
Well the guy on that link replaced the TIM, then shimmed the IHS up the same height it was before using paper - all measured with a micrometer. Even with the new IHS it performed the same or worse (can't remember)
  #19 (permalink)
Old December 20, 2012, 09:03 AM
Phill's Avatar
Currently I running prime at 4.8Ghz with 1.248v (Overnight I ran 4.8Ghz with 1.26v). Load temps are anywhere from the mid 60s to the low 70s (C). As mentioned earlier I really would like to glue the IHS back to the pcb. The issue lies with what kind of adhesive to use... any thoughts? Also do you guys think it worth investing in some Cool Labs Pro TIM?
  #20 (permalink)
Old December 20, 2012, 09:57 AM
Bungwirez's Avatar
Lol... NO. I already checked..
Originally Posted by Exculsion Criteria
... Damage to the Eligible Processor due to external causes, including accident, problems with electrical power, abnormal electrical, mechanical or environmental conditions, usage not in accordance with product instructions, misuse, neglect, alteration, repair, improper installation, or improper testing
i7 920 to i7 3770k worth it? OpTioN CPU's and Motherboards 12 December 17, 2012 06:47 PM
I7 3770k only an Ivy Bridge? Zaraydis CPU's and Motherboards 2 November 20, 2012 03:23 PM
I7 3770K Your_friendly_gamer Price Check 2 October 6, 2012 11:37 PM
i7 3770k or i5 3570k netgears CPU's and Motherboards 9 July 9, 2012 09:58 AM
Tempted by the dark side lcdguy New Builds 18 November 4, 2011 04:37 PM
