  #91 (permalink)
Old June 30, 2014, 04:08 PM
Coach's Avatar
I used a razer blade. starting at the corners and working up the sides. As per this thread I have delidded three Ivy cpus without an issue.
  #92 (permalink)
Old June 30, 2014, 07:01 PM
lowfat's Avatar
IMHO the hammer vice method is the way to go. I have delidded 3 CPUs, two with the hammer vice method and it is by far easier and feels so much safer.
@zoob make sure you remove all the glue from the backside of the IHS. That is the problem that causes the higher temperature, not the TIM.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
  #93 (permalink)
Old August 7, 2014, 03:09 PM
OK I take all I said back. I think it was mainly because I was chickens#17 and used Ceramique instead of Liquid Pro under the heatspreader.
Last night I put some electrical tape over the resistors and applied a light coat of Liquid Pro while I was moving some chips around.
Now have it at 40x100 1.23V 70C LinX (I think non-AVX) load on a HR-02 Macho with a single Scythe S-Flex F open air.
heatware
  #94 (permalink)
Old August 15, 2014, 07:50 AM
Trial Member
do I need to put the IHS back on top or can I leave it off and then put my cooler on top of that? or its too risky due to pressure break something?
  #95 (permalink)
Old August 15, 2014, 02:40 PM
KaptCrunch's Avatar
forget the heat spreader, sub with copper shim stock that's thicker then HS by .005 inch
dante`afk yes you need a spacer between cores to keep proper tension with block
  #96 (permalink)
Old August 15, 2014, 03:28 PM
lowfat's Avatar
It is a good idea to use the IHS to prevent damage to the chip. It is possible to use certain water blocks and heatsinks w/o it if you are careful though.
Queen of Dreams WIP
Big Lian Li
Complete
i7 920 to i7 3770k worth it? OpTioN CPU's and Motherboards 12 December 17, 2012 07:47 PM
I7 3770k only an Ivy Bridge? Zaraydis CPU's and Motherboards 2 November 20, 2012 04:23 PM
I7 3770K Your_friendly_gamer Price Check 2 October 6, 2012 11:37 PM
i7 3770k or i5 3570k netgears CPU's and Motherboards 9 July 9, 2012 09:58 AM
Tempted by the dark side lcdguy New Builds 18 November 4, 2011 04:37 PM
