Old December 16, 2012, 03:08 PM
OpTioN's Avatar
Default i7 920 to i7 3770k worth it?
currently have a i7 920 @ 4.0ghz that ive had for almost 4 years now. im going to be upgrading to a GTX 680 very soon and I was wondering if you guys think it would be worth it to spend the extra $$ and upgrade my cpu/mobo aswell?
Old December 16, 2012, 03:18 PM
ZZLEE's Avatar
Don't know but I am in a similar Boat.
Going 3770 K an 660 TI soon as I can spring the Cash fore the CPU. water cooled
Running i7 920 and 560 TI now. air
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old December 16, 2012, 03:29 PM
If you find your 920 lacking, then yes a 3770k would net you some decent gains. If you aren't having any issues with your fps or other uses, then there is really no need to jump ship yet, as the 920 is still quite powerful. Here is anandtech comparison of the two at stock clocks (I would think there should be a similar trend between the two once OCed).
AnandTech - Bench - CPU
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old December 16, 2012, 03:34 PM
It really depends on what you do with your PC. I don't see a 920 at 4.0 to be lacking unless your doing something like streaming without a capture card, then you'd want something like a 3930k as x264 takes advantage of all cores/threads. But keep task manager open and watch performance as you game and see if your cpu ever reaches above 80% usage.
We can only guess, if you want a definitive answer as to if it's worth it then do what you normally do but with some resource monitoring applications open and take note if you see anything maxing out or bottlenecking.
Old December 16, 2012, 05:55 PM
Honestly, if your going to make the jump to newer .... wait the few more months for the 4xxx series haswell cpu as if i go by my reading vs the previous ones to it ... it will have some nice preformance.
Old December 16, 2012, 06:00 PM
nice CPU increase? I was under the impression that we should only expect about 10%-15%.
Old December 16, 2012, 06:05 PM
I think you'd be fine sticking with the 920 @ 4 GHz. One thing about Ivy though is the lower power consumption = lower heat = quieter computer.
heatware
Old December 16, 2012, 06:32 PM
botat29's Avatar
they only change the memory controller and the IGP , so it will be about the same performance as the Ivy
The Ivy is about only 4-5 % increase over a Sandy
Old December 16, 2012, 08:08 PM
Rollergold's Avatar
I also run a 920 @ 4 ghz and has served my needs just fine for 3 years now. Deciding to upgrade or not is best determined on what you use the system for. If you want to do some HD PC game streaming or high end video editing the 3770k or even the 3930k would give decent improvements. I'm personally sticking with 920 for now though (waiting to see if Haswell-E has any chance of existing)
Old December 17, 2012, 12:24 PM
I'd wait for haswell.
I7 3770k only an Ivy Bridge? Zaraydis CPU's and Motherboards 2 November 20, 2012 03:23 PM
I7 3770K Your_friendly_gamer Price Check 2 October 6, 2012 11:37 PM
I7 3770K watercooled zati Water Cooling 1 September 16, 2012 06:27 AM
need mobo for i7 3770k karolis CPU's and Motherboards 6 July 12, 2012 08:18 PM
i7 3770k or i5 3570k netgears CPU's and Motherboards 9 July 9, 2012 09:58 AM
