Old December 17, 2012, 05:14 PM
Originally Posted by zoob View Post
I think you'd be fine sticking with the 920 @ 4 GHz. One thing about Ivy though is the lower power consumption = lower heat = quieter computer.
Only when non oc
***guess i should add some comment.
If you want overall higher performance then ivy has better performance cpu and mem due to better imc. you might even get better ram frequency's out of current ram i'm not guaranteeing that or anything but could happen if you have a good set.
Imc capable of 3000+ typically if ram is willing/board chosen.
My question is why? i have a 930 @ 4.0 here on guest pc and it does everything quite well tbh. games run above needed fps ect.
If your on a budget of any type i say save your $ for xmas shopping and family if its just gaming buy a new vidcard don't buy into the pci-e 3.0 hype its a non increase atm.
My 3 current rigs
guest - Main - Work
I7 930@4.0ghz
3770K@ 4.8ghz
2500k @ 4.7ghz
SF101 HW BOT
Old December 17, 2012, 06:31 PM
FreeKnight's Avatar
With how easily overclocked the 920 is, I'd wait for haswell and if you need it, dump 40 bucks on a good cooler for it. Hyper 212, a Prolimatech or something similar will get you some solid temps out of it.
My System - Mimir
|- Intel i7 920 -| - Corsair 850w HX Modular PSU -|- Gigabyte G1. Sniper -|- 24GB Corsair Vengeance DDR3 -|- Prolimatech Megashadow Cooler -|
- EVGA GTX 670 FTW -|-2x Crucial M4 256GB RAID 0-|- Seagate Barracuda 3TB -|- WD Caviar Green 2TB HDD -|- Corsair 600T White -|- Windows 7 Ultimate -|
Old December 17, 2012, 06:47 PM
hes already at 4.0 he wont get alot"any" more from any hyper 212 --
that said 4.0 is solid as hell for gaming like i said before.
it has 4cores 4 hyperthreads. and tons of bclock which helps alot.
not saying its faster than a oc sandy or ivy. but makes me wonder when anything better is relevant.
i should point at my sig- i have all 3 heavily oc on air -
My 3 current rigs
guest - Main - Work
I7 930@4.0ghz
3770K@ 4.8ghz
2500k @ 4.7ghz
SF101 HW BOT
I7 3770k only an Ivy Bridge? Zaraydis CPU's and Motherboards 2 November 20, 2012 03:23 PM
I7 3770K Your_friendly_gamer Price Check 2 October 6, 2012 11:37 PM
I7 3770K watercooled zati Water Cooling 1 September 16, 2012 06:27 AM
need mobo for i7 3770k karolis CPU's and Motherboards 6 July 12, 2012 08:18 PM
i7 3770k or i5 3570k netgears CPU's and Motherboards 9 July 9, 2012 09:58 AM
