Old December 15, 2012, 04:51 AM
Default CPU Temp question
So I just installed a core i5-3570k and Asrock Z77 Extreme4 mobo in my antec 900 case. Right now it is not overclocked and on the stock cooler but soon to be replaced by an antec kuhler h2o 620.
Idle temps are perfect at about 27-30°C but as soon as I start prime95 temps jump up into the 60-70°C range in seconds, but then back down again as soon as I turn it off. Is this normal/Okay? I understand the stock cooler is crap but was does it cool back down so quickly? I'm talking like 70°C turn prime95 off and less than ten seconds later it's back to 30°C.
Thanks!
Old December 15, 2012, 05:28 AM
Perfectly normal. Pretty good for stock actually.
Old December 15, 2012, 05:54 AM
Okay, Thanks!
And literally seconds after I made this thread the Kuhler showed up lol. Much better, idling at ambient (25C) andn inside of case is also 25C, haven't run a load yet.
Old December 15, 2012, 06:01 AM
Soultribunal's Avatar
Thanks!
The stock cooler is small, there really isn't a lot of surface area to be saturated by heat, so once the load is off , given the airflow inside of your case the cooler and such dispense with the heat rather quickly.
That being said, the H20 from Antec will do really well in turn for load, or should at least.
-ST
Old December 15, 2012, 06:02 AM
-ST
Cool thanks! I'm testing right now.
Upgraded form a dual core athlon to a quad core i5, faster if nothing for the Sata3 for my SSD
i7 2600k overclocked temp question zinwei Overclocking, Tweaking and Benchmarking 26 January 18, 2012 07:59 AM
SSD temp files question Shadowmeph Storage 3 August 17, 2011 01:38 PM
6970 temp question ultraman7k Video Cards 5 May 23, 2011 10:49 AM
Noob question: is there a program that tells ram temp? Gameplaywarrior RAM 19 December 3, 2008 12:55 PM
another cpu temp question madness69 Troubleshooting 3 April 4, 2008 06:48 PM
