Old December 11, 2012, 10:23 PM
Default Gigabyte 990XA-UD3 keeps dropping HDD
so I have a 990XA-UD3 system setup with a fx-8320, a samsung 830, and 2 seagate 2tb HDDs.
its been running smoothly for about 2.5 weeks. today, it started dropping one of the hard drives. I've managed to get it to drop for a second time when saving dxtory files to it; that's the only time the drive gets written to/read from.
as a note, i do not believe I installed the mobo's achi drivers. on intel systems, I preferred to use MS achi drivers based on a recommendation for stability. is this not applicable for amd systems?
do you think this is a problem with the drive itself or with the motherboard?
EDIT:
NOTE: by 'dropping,' i mean it crashes the program using the drive and it disappears from windows explorer and the partition utility in win7. on one occasion, it disappeared entirely from bios.
also, this issue seems to have affected the boot sequence off my SSD (it just goes alot slower and freezes at certain point in the windows bootup animation).
Old December 13, 2012, 12:44 PM
Soultribunal's Avatar
EDIT:
Have you changed the SATA port that the suspect Drive is attached to?
My first intiuition is the HDD but you never know.
-ST
Old December 14, 2012, 11:23 PM
pretty sure it's the drive at this point. I just don't understand it would affect boot times....
Old December 15, 2012, 12:04 AM
Stupid question but have you replace the SATA cable first? My computer was having a hell of a time accessing the drive and would eventually hard lock. It passed the WD diagnostic but still had the problem until I swap the SATA cable.
GA-990XA-UD3 sata speed with ssd is slow?! DoocMoStar LinusTechTips Q&A 6 December 5, 2012 04:11 PM
GIGABYTE Dropping Hints about New G1-Killer Motherboard Series FiXT Press Releases & Tech News 1 January 1, 2011 12:14 AM
Dropping 9800GTXs for something more Realityshift Video Cards 4 April 2, 2009 11:29 PM
can dropping hdd kill it? Cadence Storage 29 March 29, 2009 08:50 PM
Dropping BUS speed from within an OS 21YearsCanadian Overclocking, Tweaking and Benchmarking 2 March 28, 2007 02:44 PM
