Old December 10, 2012, 11:12 PM
Default MSI MPOWER Z77
I'm planning on getting a Mpower Z77 motherboard from ncix sometime this week. Does anyone have this board and have suggestions and pros and cons?
Thanks!
Old December 11, 2012, 07:56 AM
Sagath's Avatar
From the reviews on the net, the board seems a killer bang/buck ratio. HOCP and guru3d both seemed to like it, and had no problems. Its $30 cheaper then the Asus z77 pro, and has a $10 MIR on top of that, with all the features, and looks way cooler!
I also really like MSI's rma. With a return center in Toronto it makes for very easy (and fast) turnarounds, if needed. I'll be picking one of these up myself!
Originally Posted by Lpfan4ever View Post
AKG shot the hamsters, and then Perineum drove his Mustang with summer tires into the server.
Old December 11, 2012, 08:00 AM
great_big_abyss's Avatar
Yeah, nice board. I may just pick one up myself when I do an Ivy upgrade in a couple of months.
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; Sapphire HD5870; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; ASUS GTX650Ti Boost; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
Old December 11, 2012, 08:37 AM
BobbyLou's Avatar
the no offset voltage on the board is a real killer for me.
Old December 11, 2012, 08:56 AM
Soullessone21's Avatar
This has been one of the best boards I have ever owned its a work of art and OC's like it was designed to :P
Current Build:http://www.hardwarecanucks.com/forum...cube-gods.html
Always up for a Beer in Calgary or Area
“Two possibilities exist: either we are alone in the Universe or we are not. Both are equally terrifying.”
Old December 11, 2012, 09:34 AM
Pabz0r545's Avatar
I have it and I like it a lot but the one big problem many people have with it is the lack of offset voltage for overclocking. Don't bother me though :P
"Water cooling is basically like injecting drugs into your veins and you'll find that what once was enough is quickly not enough anymore."
-Linus
Old December 12, 2012, 05:43 PM
Thanks!
Don't think you can go wrong
Got rid of an Asus Z77 Pro for this and won't ever look back
Asus makes better routers than motherboards now
Offset voltage thingy is only real major non and who cares
No Intel NIC but the Realtek works fine
Extremely stable motherboard and dual bios
Hint don't just use mouse to scroll up and down in bios use arrows etc
Cambridge,ON
MSI Z77 M Power/Bios17.7
i5 3570k@4.5ghz
Mushkin #997007
Noctua NH-D14
EVGA GTX460
Seasonic X-660
Antec P280
Intel Speed Demon Equipped
using Prime 95 27.9
Old December 12, 2012, 07:06 PM
I agree with you that it looks way cooler! I've decided to get it solely because of its colour scheme! But it's good to know the board has plenty of features and good reviews too heh.
Does MSI cover shipping costs for RMA?
Thanks!
HeatWare: http://www.heatware.com/eval.php?id=83342
Old December 12, 2012, 07:07 PM
Thanks for your input! May I ask what are the benefits of using this board with an Ivy Bridge CPU? I plan to use this with a 2700k.
Ah, I will look into that.
Thanks Bobby!
Soul's MSI Z77 MPower Review and Mod Soullessone21 Member Reviews 12 October 2, 2012 01:03 PM
