Old November 29, 2012, 08:39 PM
Default Difference in these Z77 mobo
I think its upgrade time, but now am confused with these mobos, I am not sure which one to buy???
I will either get 3570k or the 2500k[will mostly get the IB]
I am going to use a GPU and Sound Card[nope, no sli]
planning to OC, not going to RAID, only 1 HDD
here is the list, and out of these, which one shld i go for?
MSI Z77MA-G45
MSI Z77A-GD65
ASUS ASUS P8Z77-VLX
Gigabyte GA-Z77X-UD3H
Gigabyte GA-Z77MX-D3H
Gigabyte G1.Sniper M3 Z77
ASRock Z77 Extreme 3
ASRock Z77 Pro4
ASRock Z77 Pro 3
Old November 29, 2012, 09:13 PM
dandelioneater's Avatar
I would do a google search for each of the boards. Usually you can find a review for each board. I usually take into account the price, warranty, and how easy it is to RMA if there is a problem. I would consider the msi gd-65 or the asus. Nothing wrong with gigabyte or asrock products though.
O/C Difference lechumbl Overclocking, Tweaking and Benchmarking 13 September 25, 2011 04:39 PM
difference between MCB 655-b vs MCB 655-01 hatabilly0204 Water Cooling 8 April 25, 2010 11:44 AM
Switched Mobo... WTF CPU Temp Difference...? shayan288 CPU's and Motherboards 38 August 20, 2009 08:33 PM
What is the difference? akbg Storage 5 October 16, 2008 04:51 PM
FS-s939 X2-3800, OCZ ram, Ac Freezer 64 Pro, ASRock mobo, DFI mobo, Asus mobo..more stoanee Buy/Sell & Trade 14 June 7, 2008 06:24 PM
