-   -   CPU Fans on 100% (http://www.hardwarecanucks.com/forum/cpus-motherboards/58084-cpu-fans-100-a.html)
SandyGames November 24, 2012 04:24 PM
CPU Fans on 100%
I have an issue. I reset my bios because i didnt want my overclock anymore and now when i turn on my pc its really loud because the fans is @ 100%. What should I do? My CPU and Motherboard - AMD FX-6100 and MSI 870-C45 FX V2. Help?
bliz November 24, 2012 04:54 PM
Enter the bios,acess to Advanced bios,and see what they say: generally different settings for CPU fan.low,normal and high speeds!
Soultribunal November 24, 2012 11:08 PM
Probably have to set the Fans to AUTO. Some BIOS controls do that as a defult when Reset as a precaution or failsafe.
-ST
sswilson November 24, 2012 11:17 PM
You might also have to find the "cool and quiet" setting and enable it. When you reset your bios, did you select the "load optimal settings" (or something similar) option and save them?
