<~----> CPU and MOBO advice for Video Production - Page 2 - Hardware Canucks
Old November 18, 2012, 10:26 PM
Finally the budge is of around 20,000[$360] including the cpu and mobo, so yea...
Old November 18, 2012, 10:56 PM
That Asus board is very low end, but I don't know if you even need things like Sata 6gbps or USB3.0. You can try looking for 970 chipset boards instead of the 990. Still cheap and offers much more than the 760g.
Old November 27, 2012, 04:18 AM
Finished my build for my little brother.
I'm not sure of all the details, but its something like this:
a 2.0GHz core 2 duo using Sony Vegas Pro to render a 15min clip at 720p used to take 3 hours. 2GB ram, SSD boot drive, HDD + external HDD for recording/encoding purposes.
a stock fx-8320 using Sony Vegas Pro to render a 15min clip at 1080p takes 45min. 16GB ram, SSD only (test was ran before we installed the hard drives).
not exactly 'conclusive,' but if anyone wants any specific tests run, let me know.
Old November 27, 2012, 10:32 AM
yea, it seems we will have to go the amd way this time, tight on budget. and thanks for running those test, appreciated
will mail you if i need any help with
new mobo need advice pls...? Kamran1981 New Builds 0 January 26, 2011 02:32 PM
New Mobo--need ram advice Surk RAM 2 December 8, 2009 07:44 AM
new i7 860 MOBO advice Sandro_Bit CPU's and Motherboards 27 September 5, 2009 06:25 AM
CPU and Mobo advice? DragonFlame CPU's and Motherboards 11 June 12, 2009 08:18 AM
Need advice on mobo? bushwickbill CPU's and Motherboards 3 August 5, 2008 03:29 PM
