-   -   Asus Z77 gene Intel or Marvell Sata controller. (http://www.hardwarecanucks.com/forum/cpus-motherboards/57632-asus-z77-gene-intel-marvell-sata-controller.html)
kyle_L October 31, 2012 10:18 PM
ASUS Maximus V Gene Z77 board and am wondering which sata controller i want to put my Intel 520 series ssd on, when i ran the AS SSD benchmark i got alot more out of the intel one, is this right or should i try it all again.
icodeit November 1, 2012 12:19 PM
I don't have the answer but would like to know as well.
BeaverBender November 1, 2012 12:35 PM
Definitely use the Intel ports.
AkG November 1, 2012 12:39 PM
Intel all the way.
Intel == TRIM. Marvell==Maybe...maybe not. Use the Marvell for your ODD when you run out of Intel ports for your SSD and HDDs....until then ignore it.
kyle_L November 1, 2012 06:17 PM
thanks for the info, i am defenety noticing a difference using it today since i switched it over.
